DS Control Center: Advice sought
Post Date: 2019-01-09
Bahger View Drop Down
  Quote Bahger Quote  Post ReplyReply bullet Topic: DS Control Center: Advice sought
    Posted: 09 Jan 2019 at 4:18pm
This is the app that monitors thermal zone data, chassis lighting, airflow optimization, etc. I must say, I hoped it would be a bit more user-friendly but the output is tiny on a high-res monitor and the color-coded lines for component temps are similarly difficult to read (CPU area and HDD area are an identical shade of yellow/brown). There is no apparent way to enlarge the display or to do things like convert temp output from C to F. I don't intend to be spending a lot of time neurotically monitoring my system temperatures but it would be nice to be able to use this tool. Just for starters, can anyone clue me in on what the "safe" temperature ranges are for the five components measured and whether there might be another little app that presents the same data in a more friendly way? Thanks!
Edited by Bahger - 09 Jan 2019 at 4:20pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 09 Jan 2019 at 4:31pm
The control software is mainly showing you fluid temps and the temps around your internal zones. If you're looking for actual hardware temps, you should check out "Hardware Monitor" which is very useful (link below):
https://www.cpuid.com/downloads/hwmonitor/hwmonitor_1.38.exe
  Quote Bahger Quote  Post ReplyReply bullet Posted: 09 Jan 2019 at 5:37pm
Thanks, Alex.
This page was generated in 0.1230469 seconds.
