DS Liquid Cooling - Parts
Post Date: 2014-03-14
gloryofthesky View Drop Down
  Quote gloryofthesky Quote  Post ReplyReply bullet Topic: DS Liquid Cooling - Parts
    Posted: 14 Mar 2014 at 6:16pm
Hi, i own a digital storm HailStorm II level 3, I actually did not put water cooling on it due to because I already owned a previous water cooling system from corsair.
Im looking to upgrade, and I was wondering what are the parts for a custom water loop?
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 14 Mar 2014 at 10:58pm
Main parts of a custom water cooling system are reservoir, pump, radiator, fans (to go on the radiator), water blocks for the components you want to cool and hosing/fittings to connect everything together... You can also multiples of the radiators, reservoirs & pumps depending on the complexity of your setup.
Here are some kits made by XSPC (minus the hoses & fittings) - these kits have the pumps attached to the reservoirs.
There are many more kits available or you can buy the parts all individually.
Hope this helps...
Edited by fstcvc - 14 Mar 2014 at 11:00pm
  Quote retirednavysnipe Quote  Post ReplyReply bullet Posted: 15 Mar 2014 at 6:09am
Do a search on the web for water cooling. You will find companies that will sell you every thing you need in a complete set. I priced out a single loop 240 mm fan/radiator cooling system for about $250.
They are not that expensive just gotta do some diligent research.
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 15 Mar 2014 at 11:32am
Frozen CPU carries a wide variety of components for custom and closed loop systems.
