DS Power Supply
Post Date: 2023-10-26
Ras View Drop Down
  Quote Ras Quote  Post ReplyReply bullet Topic: DS Power Supply
    Posted: 26 Oct 2023 at 5:53am
I currently have an 850w DS power supply. Wondering if anyone knows what cables are compatible with this specific power supply? Do i need to buy through DS? I have a ticket started but waiting on a call and looking to get an 8pin PCIE ASAP. thanks
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 26 Oct 2023 at 10:44am
I think you're wise for contacting DS. Unless you see a brand name and model listed on the PSU, then it's best to ask them. PSU cables from different manufactures aren't always identical, even though they frequently have the same connectors.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 26 Oct 2023 at 1:18pm
Look in the accessory box or a bag that came with your system. It should contain all the extra parts and cables. Did you look in the back of the case? Sometimes they are installed and stored out of the way until needed.
Good luck.
Ras View Drop Down
  Quote Ras Quote  Post ReplyReply bullet Posted: 27 Oct 2023 at 5:04am
I did find out that it is a DS logoed COOLER MASTER power supply. Was tough finding the 4.0 PCIE cable as everything these days is 5.0. They were able to dig up a cable for me. I have the DS binder and spare parts but could not find the spare cables bag.
This page was generated in 3.027344E-02 seconds.
