Dual ethernet port connecting two computers
Post Date: 2009-08-29
e06028 View Drop Down
  Quote e06028 Quote  Post ReplyReply bullet Topic: Dual ethernet port connecting two computers
    Posted: 29 Aug 2009 at 3:39am
My DS computer has dual ethernet ports and I am trying to use the second port to hook my second PC and share the broadband connection.  I am not using a router or switch to do this rather I am directly putting the cable from the second machine into the open port on the DS machine.  I thought I read somewhere that that was possible to do.  I followed the steps on the link below but after I compete the steps both machines have no connection.  If this is possible why won't it work?  I am now thinking I must use a router to do this which is what I was trying to avoid buying.
http://windowshelp.microsoft.com/Windows/en-US/help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
If you know of an easy way to do this without a router I would appreciate the help.
Thanks in advance
Edited by e06028 - 29 Aug 2009 at 3:41am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Aug 2009 at 4:26am
are you using a crossover cable? are both pcs vista?
  Quote e06028 Quote  Post ReplyReply bullet Posted: 29 Aug 2009 at 1:33pm
No I was not using a crossover cable.  Will have to look that one up.  And yes both PCs are vista.  Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Aug 2009 at 9:35pm
I believe you need to use a crossover cable the rest of those steps are not needed form what I understand, undo all those steps, then just connect the crossover cable then in network connections of the second pc you should see the main pc.
  Quote e06028 Quote  Post ReplyReply bullet Posted: 31 Aug 2009 at 4:43pm
I went ahead and bought a router.  I bought a WRT160N by Linksys and it is pretty fast on wireless.
