Dual-Link DVI connector problem
Post Date: 2008-05-07
0k7i2n8g0s3 View Drop Down
  Quote 0k7i2n8g0s3 Quote  Post ReplyReply bullet Topic: Dual-Link DVI connector problem
    Posted: 07 May 2008 at 11:56pm
I ordered  three Nvidia GeForce 8800 Ultra  cards in SLI and bought the  Gateway XHD monitor 30".  Then I soon realized I made a mistake in configuring the machine with 8800 Ultra cards, however, because those cards don't support HDCP on both links in their dual-link DVI connectors. Without that, I can't view encryted HD video content in high definition on a 30-inch LCD. I was thinking just use it to lower resolution, idk. I welcome any suggestions that will maximize the use of my 30" monitor. Thanks.
Duke View Drop Down
  Quote Duke Quote  Post ReplyReply bullet Posted: 08 May 2008 at 2:19pm
According to Nvidia's website under product specifications, the complete 8800 (series) supports HDCP, but its listed under their PUREVIDEO HD thing.
NVIDIA PureVideo™ HD Technology2
    * Dedicated on-chip video processor
    * High-definition H.264, VC-1, MPEG2 and WMV9 decode acceleration
    * Advanced spatial-temporal de-interlacing
    * HDCP capable3
    * Spatial-Temporal De-Interlacing
    * Noise Reduction
    * Edge Enhancement
    * Bad Edit Correction
    * Inverse telecine (2:2 and 3:2 pull-down correction)
    * High-quality scaling
    * Video color correction
    * Microsoft® Video Mixing Renderer (VMR) support
2 - Feature requires supported video software. Features may vary by product.
3 - Requires other compatible components that are also HDCP capable.
Perhaps you need to purchase this software from nvidia?
PUREVIDEO HD
EMAIL & MSN:
[email protected]
Duke View Drop Down
  Quote Duke Quote  Post ReplyReply bullet Posted: 08 May 2008 at 2:22pm
Actually, NM, that link above is just their purevideo technology stuff. Theres no [nvidia] software to purchase or download. Your 8800Ultra card should work.
Edited by Duke - 08 May 2008 at 2:23pm
EMAIL & MSN:
[email protected]
