Dual monitor help!
Post Date: 2014-06-10
TehGoat View Drop Down
  Quote TehGoat Quote  Post ReplyReply bullet Topic: Dual monitor help!
    Posted: 10 Jun 2014 at 3:35pm
My Digital Storm Desktop came with a small, black converter, i think it made the the cord that i plug into my tower DVI can someone link me or tell me what to search for... Or if Digital storm sells them alone? I need it, i would prefer the exact one that the PC comes with thanks!
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 10 Jun 2014 at 4:07pm
i think that black converter is for the vga cable which you don't need
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 10 Jun 2014 at 5:50pm
I believe you are talking about a DVI to VGA convertor. You can buy them from anywhere but it is only necessary for older monitors. If you have anything that is modern it should have HDMI or DVI that you can use.
  Quote TehGoat Quote  Post ReplyReply bullet Posted: 10 Jun 2014 at 6:25pm
My monitors have HDMI but the inputslot on my tower is much smaller than the usual hdmi
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 10 Jun 2014 at 10:39pm
That's odd, all graphics card usually feature a full HDMI plug. Are you able to take a picture?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Jun 2014 at 3:08am
Are you using the video card ports located below the rear fan and running horizontal or the motherboard ports next to the fan and next to the USB ports ?    The video card ports , what you need to use, might have black plastic caps covering them.
Let us know how you make out.
TFD_Industries View Drop Down
  Quote TFD_Industries Quote  Post ReplyReply bullet Posted: 11 Jun 2014 at 7:31pm
Might be a mini HDMI port which you will need to buy a mini HDMI to HDMI cable/converter.
