Dual Monitor question
Post Date: 2010-01-27
Ballsatronic View Drop Down
  Quote Ballsatronic Quote  Post ReplyReply bullet Topic: Dual Monitor question
    Posted: 27 Jan 2010 at 11:42am
With my new DS system I'm getting an 5870 graphics card. Is it possible to run a dual monitor set up with one HD monitor and one regular lcd? Or do both monitors have to be same as in both are either HD or regular lcd. This is probably a stupid question but I don't know much about this stuff. Thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Jan 2010 at 12:58pm
eyefinity I think you need to have the same res for both, but other then that it would be fine, but I'm no expert in the subject so I could be wrong about eyefinity.
pulsedrive View Drop Down
  Quote pulsedrive Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 3:37pm
You should be able to specify whatever resolution you want for either monitor.  Also using different monitors should not be an issue either.
