DVI Cable Question
Post Date: 2013-01-13
BShizzleUniBrizzle View Drop Down
  Quote BShizzleUniBrizzle Quote  Post ReplyReply bullet Topic: DVI Cable Question
    Posted: 13 Jan 2013 at 3:43am
Good morning forum! I Have a quick question. My DSO rig is on it's way Awesome and I just want to make sure I have the proper cable. Im currently useing 2x SLI gtx 680 4gb and the monitor I have for the time being is a Dell u2412M. I do minor graphic design and rendering along with intensive gaming. My question is, the dvi cable that came with my monitor is a single link, I believe? I see some people say go with a dual for the bandwidth. Does it really matter or can I stick with the cable I have now?
Thanks for any input.
Cooler Master 942 HAF X
Core i7 3930K 3.2GHz/4.5GHz
16GB DDR3 1600MHz
3TB SATA
2x SLI GTX 680 4GB
Win 7 Pro x64
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Jan 2013 at 4:06am
Good morning   BShizzle....   For that monitor a single link is fine.   The dual link is for higher res like 2560x1600.    The single link has space between 2 x9 pin count and the dual link is filled in with 6 more pins.
Enjoy when it arrives.
  Quote BShizzleUniBrizzle Quote  Post ReplyReply bullet Posted: 13 Jan 2013 at 4:10am
Will do thanks a lot! Big%20Smile
16GB DDR3 1600MHz
3TB SATA
2x SLI GTX 680 4GB
Win 7 Pro x64
