Dying My Liquid Cooling Coolant
Post Date: 2008-11-06
jtspectra2 View Drop Down
  Quote jtspectra2 Quote  Post ReplyReply bullet Topic: Dying My Liquid Cooling Coolant
    Posted: 06 Nov 2008 at 7:01am
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=47
do you think it would be safe to use this on my DS system , for an added effect to my liquid cooling ?
Edited by jtspectra2 - 06 Nov 2008 at 7:03am
FLighT View Drop Down
  Quote FLighT Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 7:45am
Warranty wise I'd get a ruling from DS before using /adding anything.
If it ain't broke, fix it until it is.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 2:15pm
why don't you use the same coolant as they use but a different model
always call and ask to make sure your warranty is ok like FT said
bradesco View Drop Down
  Quote bradesco Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 2:36pm
Wow.. how many times you have to fill up? That stuffs not cheap...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 3:34pm
you are looking at the big sizes I think, all you need is one of those $29 bottles to just top off if needed.
  Quote Alex Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 4:37pm
No problem.
If your pump dies, and we notice the liquid is a totally different color, you would need to buy a new one Disapprove.
Warm Regards,
Alex
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 5:11pm
how much does a pump cost ??, and DST . the product i'm looking at is a dye. meaning all i have to do is drop 1 or 2 drops into my coolant and im ready to go. the fluid xp , in order to get that UV effect needs to be completely replaced. im just looking for an easy alternative
Edited by jtspectra2 - 06 Nov 2008 at 5:12pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 5:14pm
I just thought that the dye would ruin your warranty but the actual fluid change might not, but I understand where you are coming from
Edited by DST4ME - 06 Nov 2008 at 5:15pm
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 5:28pm
ya thats tru. i cant seem to find fluid xp thats UV sensitive in the color im looking for. i may just try this stuff. i just wanna find out how much a water pump is before i go and mess with anything
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 5:52pm
if you know how to change it, then its not much, but if you have to send it to DS then think about shipping fees, labor fees, new liquid fees, etc.
pumps run about around $70 bucks I think.
Edited by DST4ME - 06 Nov 2008 at 5:52pm
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 7:33pm
http://www.xtremesystems.org/Forums/showthread.php?t=206805
This seems to scream "Don't use em!"
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 8:40pm
Thank You Axel. I WILL NOT be buying that dye. when i send my system back to DS for a 3rd GTX280 i will ask them if they can change to UV liquid .
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 8:45pm
thats a great idea jtspectra2, and the best one too
  Quote Alex Quote  Post ReplyReply bullet Posted: 06 Nov 2008 at 8:53pm
That's a better idea.
Cheers,
Alex
