Ethernet Cable?
Post Date: 2020-06-05
Sterod12 View Drop Down
  Quote Sterod12 Quote  Post ReplyReply bullet Topic: Ethernet Cable?
    Posted: 05 Jun 2020 at 2:09pm
Would I need a Ethernet cable when I get my pc or does it come with built a WiFi ?
  Quote Snaike Quote  Post ReplyReply bullet Posted: 06 Jun 2020 at 1:07am
Hi Sterod,
I moved this to it's own thread to make sure that your question didn't get lost in that thread.
Post your configuration / Make & Model and The Smart Guys® will be along to help out.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Jun 2020 at 3:50am
I had to get my own ethernet cable back in the day. I think it would very wasteful as the majority of us would already have one. Also, length needed would be a major issue.
Muz View Drop Down
  Quote Muz Quote  Post ReplyReply bullet Posted: 06 Jun 2020 at 5:40am
Yes, you need your own ethernet cable for sure but depending on your MOBO, you might have wireless capability. I would still personally get a cable and I would suggest nothing less than a CAT 6 cable.
HcpzHype View Drop Down
  Quote HcpzHype Quote  Post ReplyReply bullet Posted: 06 Jun 2020 at 6:32am
Well if you do not have a built in wifi card or wifi dongle yes you will need the ethernet cable, but good thing is that its is so simple to install a wifi card if you want wireless or just buy a dongle
jc
