EVGA 3xSLI X58 Classified cpu cable
Post Date: 2010-03-10
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: EVGA 3xSLI X58 Classified cpu cable
    Posted: 10 Mar 2010 at 12:58pm
Hello
As the other guys that have bought the same motherboard as me + the Corsair HX 1000W:
I have connected the frist cpu slot, but I want to connect the other one too, for overclocking.
But I do not have a cable that says CPU.
(I used the one that came with the board + the extension cable since I have the Corsair 800D case.
Can I use a PCI Express cable, 8pin 12V, plug it into the black part of the PSU and plug it to the other cpu power plug on the mobo? (As I said, I want both of them connected, now I only have 1 of them)
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 1:04pm
one is enough for any overclocking you are going to be doing, but lol look at your 8 pin's one is unlike the others, lol thats the guy you use for the second mobo powa
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 1:10pm
I hope that was clear, lol do not use the PCIe powers cables, the 6+2, there is one ATX 8 pin besides the one that is labeled CPU
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 1:40pm
yeah but the problem is. I used the 1 for the first cpu, and I also used the extension cable. Are there enough cables from the box in the PSu & the mobo u saying? (remember I need a longer one for the Corsair 800D case)
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 2:05pm
Might want to re-think you wire routing so you do not use the extension
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 2:25pm
You have to use the extension with this case.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 2:32pm
no you don't
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 3:20pm
You don't? But I arrange the cable behind the mobo of course. Can you explain how? I really don't understand how I can make it.
Anyways. I don't understand what other cable I will use to connect the other cpu cable. What cable do I use? PCI ex?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 3:30pm
I think that power supply has 6 PCIe 6+2 connectors, and 2 8 pin ATX connectors, plug the 2 8 pins ATX connectors into the motherboard
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 4:34pm
IF you mean the ones that are not modular, the ones that you cant remove, there is only one 8pin ATX
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 4:47pm
So if the cable goes behind the mobo, like in through the wall, you still do not have to use the extension to reach the mobo with the atx cable?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2010 at 4:57pm
lol hate to have to post a picture of what you have in front of you but maybe this will make sense?
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 11 Mar 2010 at 11:29am
Yeah I found out. But still, I have problems making the cable reach the motherboard without using the extension cable. Can you explain exactly how you made it there?
I mean, we are talking about the corsair 800D. So the cables go behind the motherboard in the wholes.
Muz View Drop Down
  Quote Muz Quote  Post ReplyReply bullet Posted: 11 Mar 2010 at 12:07pm
WOuld it be possible for you to take a picture on the insude of your case?
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 11 Mar 2010 at 12:21pm
I can, but there are a lot of videos online and also on the corsair webpage about the case.
I have the EVGA 3x SLI Classified motherboard, 1000W HX Corsair PSU + Corsair Obsidian 800D case.
I thought most people knew about these 3 parts, since they are hot at the moment, and a lot of people buy them.
