External Hard Drive Question
Post Date: 2011-09-07
ziggy View Drop Down
  Quote ziggy Quote  Post ReplyReply bullet Topic: External Hard Drive Question
    Posted: 07 Sep 2011 at 9:02am
Any of you folks use external hardrives? Are they reliable? Which are the better brands?
Unlicensedhitman View Drop Down
  Quote Unlicensedhitman Quote  Post ReplyReply bullet Posted: 07 Sep 2011 at 4:01pm
I like to use 2.5" / portable hard drives because they don't require a AC adapter and they consume less space. I don't really buy a particular brand because most portable hard drives are 5400 RPM. Instead I buy an external enclosure and add a Hitachi or Seagate retail 2.5" 500GB or 750GB 7200 RPM hard drive.
I always run a SMART test before I start transferring files to them. I make sure they are in good health before I start using them. If they are in bad health, I go back to the store and exchange for a new one, which rarely happens.
As for buying any 3.5" external hard drives, I would recommend doing the SMART test before you start using them to prevent data loss in the future. I think personally, if you want reliability, you should go buy them at a computer store and sure you do the SMART test. They buy in bulk, so they handle the shipping for carefully than if you were to order it online.
Digital Storm xm15 laptop
-15.6" (1366x768)
-Windows 7 HP 64-bit
-Intel Core i5 2.4 Ghz
-Nvidia GeForce 330GT 1GB + Intel HD w/ Nividia Optimus
-6GB DDR3 ram
-Intel 80GB SSD
-Intel Wireless N 6300
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Sep 2011 at 4:51pm
As mentioned its best you go buy your own external enclosure and add your own hdd, if you get a good enclouser, it will support both 3.5" and 2.5".
most of the drives are good but you can't tell when or if a drive goes bad, they can pass tests with flying colors but die a month later, tho a smart test maybe able to tell if your drive is not in a great condition at that time, but if it passes, it does not mean it won't die next month.
I like to clone(duplicate) my drives as backup.
you can follow my clone guide here, and at the bottom some info on external enclosures.
Edited by DST4ME - 07 Sep 2011 at 4:52pm
