extreme case 5th fan ??
Post Date: 2008-02-10
Guest View Drop Down
Guest
Guest
  Quote Guest Quote  Post ReplyReply bullet Topic: extreme case 5th fan ??
    Posted: 10 Feb 2008 at 5:52pm
OK, I went and saw the pictures of case's at the manufactures website,, one question,,, the Extreme case specs show it can take 5 fans,, ok. i can account for 4 of them,, but when it says it has a side mounting fan slot,, ugh,, where would that be ?? am i thinking you have to mod a hole in the side ??  cause i cant locate where one to go,, unless i would have to mod a hole in my side panel,,
sundowner View Drop Down
  Quote sundowner Quote  Post ReplyReply bullet Posted: 10 Feb 2008 at 9:51pm
Cooling System
 Front  1 x 120mm fan slot between HDD cages
 Rear  1 x 120mm exhaust fan, 1200rpm, 21dBA
 Side  1 x 120mm mid-section fan, 1200rpm, 21dBA
 Top  2 x 120mm fan slots
 Bottom  --
 Internal  --
Pro case with extra fan
Quad Q6600 2.4 OC'd 3.1!
Nvidia 8800GT
Asus Maximus Formula Mobo
2xgb 800mhz corsair
xfire - xuntiltheendx
Kenny View Drop Down
Digital Storm Engineering
  Quote Kenny Quote  Post ReplyReply bullet Posted: 10 Feb 2008 at 10:34pm
You only can install the 5th fan between the top and bottom hard drive holder to make your hard drives cooler, if you can not see that space, you just remove the top hard drive holder, and you will see it there.
We're here with you !    &(*_~)&
