Fan Control on Velox
Post Date: 2021-02-02
Myrkul23 View Drop Down
  Quote Myrkul23 Quote  Post ReplyReply bullet Topic: Fan Control on Velox
    Posted: 02 Feb 2021 at 1:54pm
I've had my Velox PC for almost a year, and today out of nowhere the case fans are constantly on what sounds like the max speed setting. It's extremely loud and I don't know of any way to control this. I have made no software or hardware changes, and my CPU temps are in the low 30s.
Does anyone know how I can change this?
JoeK View Drop Down
  Quote JoeK Quote  Post ReplyReply bullet Posted: 03 Feb 2021 at 6:29am
Shut down the PC. When it reboots smash the DEL key and it will bring up the bios. You can always Google it, but I just looked around and you can adjust you're fan curve for the PC. Hope that helps!
Ordered/Stage 1- 12/11/2021
Stage 2/3- 01/27/2021
Stage 4- 01/28/2021
Stage 5- 01/29/2021
Stage 6/7/Shipped- 02/01/2021
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 03 Feb 2021 at 11:24am
I tried entering the BIOS but there are no entries for the system fans... just the CPU fan which is running at normal speed.
I confirmed it's the system fans (specifically the two fans at the top of the case), since if I shut off those fans with the switch that DS installed the noise stops instantly. So really the question is how can I modify these fans to go back to auto speed rather than max?
JoeK View Drop Down
  Quote JoeK Quote  Post ReplyReply bullet Posted: 03 Feb 2021 at 12:31pm
Did you get the corsiar fans with the case? If so you can download the program and adjust them from there in sure. I would honestly call DS and talk to someone in tech
Stage 4- 01/28/2021
Stage 5- 01/29/2021
