Fan Noise (clicking sound)
Post Date: 2020-11-04
kzheng14320 View Drop Down
  Quote kzheng14320 Quote  Post ReplyReply bullet Topic: Fan Noise (clicking sound)
    Posted: 04 Nov 2020 at 11:39pm
Hi guys I got my custom lynx pc a few months ago and everything works fine but i keep hearing this clicking noise that I believe is coming from the cpu cooler, is this normal and is it a problem? I have attached a zipped video of it. Thanks for any help.
here are my System Configuration if needed:
Chassis Model: Digital Storm Lynx
Processor: Intel Core i7-10700K (5.1 GHz Turbo) (16-Thread) (8-Core) 3.8 GHz
Motherboard: ASUS Prime Z490-P / MSI Z490-A Pro (Intel Z490 Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
Power Supply: 600W Digital Storm Performance Series (Supports up to an NVIDIA RTX 2070 GPU)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD (500GB Digital Storm Performance Series)
Internet Access: Wireless PCI-E ASUS PCE-AC56 (Supports 802.11ac)
Graphics Card(s): 1x GeForce RTX 2070 SUPER 8GB (VR Ready)
Add On Card: - No Thanks
Extreme Cooling: H20: Stage 1: Digital Storm Vortex Liquid CPU Cooler (Single Fan) (Fully Sealed + No Maintenance)
Chassis Fans: Digital Storm Performance Series (RGB Fans)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Nov 2020 at 4:25am
I don't think it's normal and I do think it's a potential problem. There is a pump in there that needs to be free-running and not making noise. Sometimes a mechanical part can get just a few microns out of whack and make noise. I'm really old, and sometimes you can just give it a little tap or two, and it will work fine. If it were mine, I'd try that. Maybe flick it with your finger a few times. If the noise won't stop, or stops and then comes back, you need to contact DS tech support because your CPU cooler is faulty. Sorry.
