Fan Speed Control software
Post Date: 2009-08-07
Ashenra View Drop Down
  Quote Ashenra Quote  Post ReplyReply bullet Topic: Fan Speed Control software
    Posted: 07 Aug 2009 at 1:45pm
  Hello , Got my new DS everything is great --as expected Smile My question is this Do either EVGA Precision 1.7.1 Or RivaTuner 2.24 work with Vista Home Premium 64 bit and XFX Gtx 275 GPU ? Any reccomendations appreciated. The system is very quiet and has had ZERO glitches so far , still would like to check fan speeds and find out if I can adjust them.
Edited by Ashenra - 07 Aug 2009 at 1:49pm
There are only Two choices : Get Over It or Get Used To It
Semper Fi
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 07 Aug 2009 at 3:24pm
I love EVGA Precision, seems to work with any nVidia card, works like a charm with my Zotac branded cards. and the interface is alot easier to use than Riva in my opinion.
Dave Ouch
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Aug 2009 at 6:19pm
if precision does not, riva will for sure.
  Quote Ashenra Quote  Post ReplyReply bullet Posted: 07 Aug 2009 at 7:05pm
ok Thanks Big%20smile
Semper Fi
jean luc picard View Drop Down
  Quote jean luc picard Quote  Post ReplyReply bullet Posted: 08 Aug 2009 at 1:22pm
I downloaded the evga software too.My question is when you adjust the fan speed in a sli setup,do you leave the adjusted speed on all the time,even when your not gaming?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Aug 2009 at 1:31pm
set both gpus to auto jlp, that way when needed the fan go to high and when not needed they stay on low.
Edited by DST4ME - 08 Aug 2009 at 1:32pm
