Fan speed software
Post Date: 2010-10-09
rayfinkle View Drop Down
  Quote rayfinkle Quote  Post ReplyReply bullet Topic: Fan speed software
    Posted: 09 Oct 2010 at 6:47pm
I know this has been posted before, but what is it again? I couldn't find it. I'm talking about the program where you can set fan speed for certain temps, etc.
Thanks!
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 12:16am
Speedfan is probably the best one out there. http://www.almico.com/speedfan.php keep in mind for it to work your fans need to be hooked up to the motherboard and it doesn't work with all motherboards.
Steam:pcmaster160
JJJJ_Shabadoo View Drop Down
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 9:44am
Im assuming you mean GPU fan speed. If so, use MSI Afterburner
  Quote rayfinkle Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 10:41am
I was talking about both really. Is it a bad idea to make such settings on the non-gpu fans? For someone who is just getting started on exploring my computer. :P
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 10:46am
Unless your case fans are annoyingly loud, I'd just leave them be. Airflow in the case will effect the temps of all your components.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 12:12pm
how do you connect the fans to the motherboard? and is there room for all 5?
Steam:pcmaster160
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 2:12pm
depends on the motherboard, each has thier own amount of fan headers
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 2:21pm
k i'll look into it.
Steam:pcmaster160
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 6:27pm
never hook fans to the mobo header..you are asking for more trouble than  sitting on the corner calling all the ladys that walk buy  fat.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 6:35pm
why?
Steam:pcmaster160
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 6:49pm
Originally posted by maxyme
why?
Some case fans draw in more current than others, so if you connect a fan to the header that draws in more current than the header's rating, it will burnout making the header useless.
Either connect via PSU running at max speed or via fan controller.
Edited by AmbientChong11 - 10 Oct 2010 at 6:50pm
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 6:51pm
but isn't the fan header useless already if you don't use it? haha and thanks for the information but it can't burn out the whole mobo right?
Steam:pcmaster160
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 7:17pm
Yes, it's useless but if you want to control the fan speed like you would on a video card, the fan needs to be connected to the MB via headers or else the speed would be locked if using the PSU 4 pin molex to power the fan or buy a fan controller.
It wouldn't make the MB useless. It would be insane for a $10 fan to fry your $300 MB. You're welcome.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 7:25pm
haha that would suck! just being over cautious i guess.
Steam:pcmaster160
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 7:29pm
why?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 8:53pm
mobos are very under powered, that is why we have evolved the high performance motherboards with (2) 8 pin power connectors, and 2 ,molex connectors added to the 24 pin connector. tons of stability issues due to low voltage, voltage sag, and we all know that watts =  volts x amps, so voltage drops, amp must increase to maintain the same power, and then boom.. lol putting 5 high speed fans on an already starving board is a bad idea.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 9:16pm
makes sense, i just dont do it becuase i have no interest in a fan running at less than 100%
still waiting to see if anyone can tell me if there is a simple in line fan controller that will hook between the power cable and the fan itself and allow analog fan speed control, like a stereo knob sort of
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 9:25pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Oct 2010 at 10:18pm
yes exactly like that
$31? geez
thanks for the link tho
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 12:32am
or make it yourself Hahaha
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 12:49am
Hey Justin, I saw you about 5 minutes ago ..... on MaximumPC.
Nice writes !!
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 8:49am
http://www.maximumpc.com/user/justinkerr_0
if you are talking about this guy, its not our justin kerr
look at his PC stats:
"Intel Core i7 920 Processor Overclocked To 3.6Ghz
6 GB Patriot Tripple Channel DDR3
Kingston SSDNow V Series Gen II 128GB"
LOLLOL
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 9:33am
Hey Justin, can multiple fans be hooked up to the rheostat providing the max. output fan wattage does not exceed 25 watts?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 9:36am
i was actually thinking.. what if you took a controller like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16811998808&cm_re=fan_controller-_-11-998-808-_-Product
and tore it apart, just used the knobs individually?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 10:09am
yes, hook a ton of em togther, if you need, they make much larger rheostats, also can google potentiometer
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 10:11am
don't think it would work, just buy a good, seperate rheostat. Big%20Smile
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 11:31am
What do you think of this little guy justin?
Zalman fan mate
its an ugly little thing, but seems to please most everyone who got it
this one seems a little better, less cheapy looking
Edited by !ender_ - 11 Oct 2010 at 11:43am
jerma View Drop Down
  Quote jerma Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 12:08pm
just a random thought here.
I have the Storm Sniper case from CM. There are 4 case fans which are controlled by a dial on the top of the case. Is it a bad thing to turn it down and up often? I usually have it at the low speed for browsing, email, etc; During Video editing or gaming I usually turn it up all the way.
I'm assuming this is all going through the mobo because I didn't buy anything to control it. So is the general consensus that you shouldn't be messing around with mobo controlled fan dials?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 12:35pm
the dial is controlling the fan speeds. just keep an eye on your temps, but I would imagine your temps will be fine, as long as the fans are still turning.
then you can set them with software. you indecisive bot you. LOL
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 12:56pm
lol thats just rediculous, im going to get the frozen one, i'll see how that works out
for the cost of that thing i could just buy 2 -3 silent fans! lol
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 11 Oct 2010 at 2:38pm
LOLLOL
Lol, I was at first suspicious too but his background info was what made me thought it was the DS Justin Kerr.
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 12 Oct 2010 at 5:34am
[/QUOTE]
[/QUOTE]
Thank you for the info.
