Fan upgrade question
Post Date: 2019-04-30
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Topic: Fan upgrade question
    Posted: 30 Apr 2019 at 8:31am
In the config section of this site, how many fans are included for each fan upgrade? thx
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 30 Apr 2019 at 10:23am
Depends on the case and components chosen.   You can get specific about those details with DS by talking to them about your selected build.   You can have your build exactly the way you want it.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 May 2019 at 1:40am
An example is my Lumos build with Corsair ML Pro fans........they installed 6 upgraded fans, 3 in the front, 2 on top and the rear fan.   Looks awesome and dead quiet. They also kept the 2 original Corsair cooler fans in a push/pull on the rad.
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 01 May 2019 at 12:03pm
thx
