Few question about Vanquish II level 4
Post Date: 2014-05-02
Reaverone View Drop Down
  Quote Reaverone Quote  Post ReplyReply bullet Topic: Few question about Vanquish II level 4
    Posted: 02 May 2014 at 4:41pm
I been thinking about buying a Vanquish II level 4 I just have a couple of question
1 is there any way to customize Vanquish II meaning if I want bigger hhd or another os like windows 7?
2 is there room to put in a 3 hard drive and if not can a Samsung 120 gb be upgraded to a Samsung ssd 1 tb or lower drive
3 this is a question for anyone who bought Vanquish II level 4 is there any thing on the Samsung 120gb ssd card ?like the Os it proubly on the 1tb drive but just checking
4   Is the power supply big enough handle 3 rd hhd or a bigger hhd
As you can tell I don't know much about computers but if I have to install a bigger hhd if the hhd I am replaseing has nothing on it do I just unhook hhd with it unplugged off course and hook larger one in and power it up?
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 02 May 2014 at 5:24pm
The Vanquishes are prebuilt and can't be customized. There are i believe 8 expansion slots for the drive bays. The OS is installed on the SSD drive.
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 02 May 2014 at 5:34pm
The motherboard in the Vanquish II Level 4 has 2 SATA 6Gbps ports and 2 SATA 3GBps ports. So you will only be able to add one more drive. One is used for the SSD, one for HDD and one for the Optical drive. You could add another SATA controller card the it in the lower PCIe 1x slot, those are not particularly expensive.
The Vanquish line are the best price performance DS offers, since they are sold as is and pre-built.
Edited by danjw1 - 02 May 2014 at 5:37pm
  Quote Reaverone Quote  Post ReplyReply bullet Posted: 02 May 2014 at 5:34pm
Edited by Reaverone - 02 May 2014 at 5:50pm
  Quote Reaverone Quote  Post ReplyReply bullet Posted: 02 May 2014 at 5:49pm
So it means I can add either hhd or ssd without haveing to install sata card right? And is power source big enough handle it without it bogging down if I get 4 tb hhd or a1tb ssd? If someone can answer this I will be alset thanks
Edited by Reaverone - 02 May 2014 at 6:17pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 May 2014 at 3:07am
Correct.   You can add another drive without the need for any cards and the power supply is plenty. Drives use very little juice.
