Fiber net speed problem
Post Date: 2010-03-18
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: Fiber net speed problem
    Posted: 18 Mar 2010 at 12:43pm
Hello
I have bought the fastest Fiber speed network I can find here in Hungary (Might be better somewhere). I bought the UPC Fiber 120/20 Mbit/s.
But When I do the speedtest, I get like 30-34Mbit/s, and 5Mbit/s up.
They told me I would at least get 90down and 10up.
I tried my laptop, an XPS M1730, it got around 100down, 15 up. I do not know if it has a good network card or not. haven't checked it.
My desktop which doesnt get the speed has the pecs as following:
EVGA X58 3x SLI Classified
920 i7
Corsair Dominator 1600MHz 6Gb (3x2Gb)
Sapphire radeon ATI HD 5870
320Gb Barracuda
Corsair H50 cpu cooler
Corsair Obsidian 800D
Corsair HX 1000W PSU
Is it that I dont have a good additional network card?
NB! All the testing was done with cable connection directly into the modem!
If you can help, please do so!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 2:36pm
you testing with the same file and server? or are you doing a speed test?
do both the laptop and desktop have the same firewall?
Edited by DST4ME - 18 Mar 2010 at 2:36pm
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 3:28pm
I am doing a speed test
yes, the laptop and the desktop has the same firewall / same antivirus. (ESET)
But I think the laptop has a network card added on it. Can this do the difference? Does the EVGA classified offer enough net speed for my connection?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 6:24pm
yes the lan port will support speeds much higher then what you have.
do both run win7?
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 6:49pm
Ok
Just to be clear, the LNA port you are talking about, that is what there is in net-cards? (Cards you put in the pci slot)
No the computers have different OS:
Desktop Win7 Prof 64
Laptop WinVista Premium 32
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 6:53pm
sorry, LAN port is what I mean
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 6:55pm
the classified has 2 lan ports, no pci card.
could be the os, is the win7 firewall disabled?
do a msconfig and disable all non ms services and then go to startup tab adn disable all startup apps, reboot and then when you get back to desktop, run the test again, don't do anything else or run anything else and lets see what happens.
when doing the speed test, are picking the same location for both laptop and desktop?
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 7:08pm
The windows firewall is disabled. The only firewall on is the one in the ESET antivirus. Is it necessary to have firewall?
Will buying a network card make the speed faster?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 7:11pm
yes you need to have a firewall.
I doubt the problem is with the mobo's lan ports, you could go and buy a network card just to get the same results.
do what I said with msconfig and then lets see what you get.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 24 Mar 2010 at 12:46pm
I disabled the msconfig stuff. And I found out the problem is from the operator. I will call them and arrange them to come and fix.
