Final Advice and Questions Prior to Purchase
Post Date: 2012-07-03
BiohazardX-87 View Drop Down
  Quote BiohazardX-87 Quote  Post ReplyReply bullet Topic: Final Advice and Questions Prior to Purchase
    Posted: 03 Jul 2012 at 7:02am
Estimated Purchase by the end of the week if all goes according to plan. I had posted earlier and had great advice and help and wanted to repost for final updates and questions.
Looking to purchase a new 24 inch LED monitor to play at 1920x1080.
Still trying to hover around $3000, but save where I can to pay for the monitor.
Config: 704564
$2892
My usage will still primarily to play online gaming BF3 mainly for now as well as upcoming PC release in the FPS genre hopefully at high resolutions, some photo editing in the near future. And general browsing the internet and completing basic tasking for work.
Currently have not moved into my new place with high speed, so for now I am operating with satellite internet. While it is faster than dial-up, but the delayed communication time prevents actual online gaming at this point in time.  So if something new is about to be released that I am unaware of, I am willing to wait.
I was contemplating upgrading the memory from 8 to 16 just in the event of heavier photoshop usage, but decided I will deal with delays in function as it will not be that common unless I get advice otherwise.
I know that I should at least get Windows Professional 64bit, but is there any benefit to going to Ultimate?
I am also going to be asking for the additional top mounted case fan as I had found out was possible via this forum and getting the extra warranty if I purchase in time.
Also, the free shirt which I just realized I forgot.
Thanks in advance
Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Force GT Series CSSD-F120GBGT-BK) (SATA 6Gbps)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Optical Drive 2: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Exclusive T-Shirt: - No Thanks (will change this)
Priority Build: - No Thanks
I may also dump the 2nd optical drive as it is merely a convenience for me not a necessity.
Thanks in advance.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Jul 2012 at 7:34am
Hi BioHazard-87.....That build is right on.   Awesome
You don't need the video and OS boost, but your call.    The cards wouldn't see any benefit for the small amount they do and I always think you are better of deciding what you want and don't want in OS.  It does come bloat free.
Grab that t-shirt.Hahaha
Great rig and let us know how things go.  Best of Luck.Big%20SmileBig%20Smile
Edited by bprat22 - 03 Jul 2012 at 7:35am
  Quote BiohazardX-87 Quote  Post ReplyReply bullet Posted: 05 Jul 2012 at 11:59am
Purchase delayed for at least 2 weeks
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 05 Jul 2012 at 12:06pm
uhhhh that stinks how come?
  Quote BiohazardX-87 Quote  Post ReplyReply bullet Posted: 06 Jul 2012 at 3:23am
Just some potential changes in my financial situation that may or may not happen here in the near future so I just have to wait. Still determined to purchase though.  Worst case scenario the components may get a few dollars cheaper while I wait.
