Firmware for Atapi
Post Date: 2008-07-21
ziggy View Drop Down
  Quote ziggy Quote  Post ReplyReply bullet Topic: Firmware for Atapi
    Posted: 21 Jul 2008 at 8:01pm
Anybody have the Atapi DVD A DH 20A4P 9P54 DVD-Ram? Are there any firmware updates for this? I found a stock one...would that be updated firmware?
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 25 Jul 2008 at 2:43pm
The rule of thumb with firmware updates due to the danger level, unless you are experiencing an issue the firmware release notes say is fixed in that update, never update firmware.
there is no upside and a huge downside, if you screw up a firmware update you can make that expensive hardware into an expensive paperweight. There is usually no way to undo a screwed up firmware update.
Dave
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
