First build attempt
Post Date: 2008-07-07
thefrogger View Drop Down
  Quote thefrogger Quote  Post ReplyReply bullet Topic: First build attempt
    Posted: 07 Jul 2008 at 5:22pm
I play FPS and other games at 1680x1050. Exact budget isn't critical, but it seems like I can get something  <$2K since I'm not seeking the bleeding edge. This is mainly a productivity machine including compiling, so the Raid0 Raptors were a given. And I'm not planning any overclocking so that I can maintain the best reliability.
Here's the config ticket: (most specs also listed at bottom)
http://www.digitalstormonline.com/comploadsaved.asp?id=165008
And my specific questions:
Noise level is important to me, so any changes on case or otherwise are welcome.
This will be my first multi-core CPU system, and I'm unsure whether to go with dual or quad. Better multitasking performance on the quad sounds beneficial, but I don't know if I'd really notice the difference, and/or if I'd notice any speed reduction with a slower quad. (Looking back, the E8400 looks like a good price point for the dual, making a switch to quad an even bigger speed reduction).
I'm assuming 667MHz memory is okay for a non-overclocked setup.
I don't expect to run SLI video, so I compromised the following to reduce price:
Power Supply: 550W Corsair HX (Dual SLI Compatible) (Silent Edition)
Motherboard: NVIDIA 650i Core 2 Quad (Chipset: nForce 650i Ultra)
Thanks for the forum to review specs like this.
John
Chassis: Antec 900
Processor: Intel Core 2 Duo E8200 2.66GHz (1333MHz Front Side Bus)
System Memory: 4GB DDR2 Corsair at 667MHz
Hard Drive 1: 150GB Western Digital Raptor (10K RPM) (16MB Cache)
Hard Drive 2: 150GB Western Digital Raptor (10K RPM) (16MB Cache)
Raid Option: Setup hard drive 1 and hard drive 2 in a Raid 0 Stripe Configuration
Hard Drive 3: - No Thanks
Video Card: ATI Radeon HD 4850 512MB
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 5:53pm
If noise level and reliability is a concern, I'd suggest a SSD because Raptors can be quite loud.
A slower quad is almost always better than a faster duo, just depends on what type of software you are using. The Q9450 is the popular choice atm for $2000 builds.
If you decide to switch to a quad core, you will have to switch your motherboard to a 750i or 790i or Asus Rampage because the 650i does not support quad cores.
You need a 64-bit operating system to utilize 4GB of ram.
  Quote thefrogger Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 8:54pm
Thanks harlyman and skyR for the responses.
I'm running twin 80GB Raptors right now, although they're in a case with insulating sound foam so it isn't a problem. They may well be objectionable in different case styles.
The SSD option does indeed sound intriguing though. I could config with two 128's, and get close to the same storage space, with tons more speed and no noise. Any drawbacks to them other than the price?
Okay thanks, I appreciate the recommendation. On the MoBo, the 650i itself is specced by nvidia and the DS dropdown to support quad core. I used this comparison:
http://www.nvidia.com/page/nforce_600i_tech_specs.html
...and didn't see anything in particular between the 650i and the 780i that looked critical. Is it just the specific MoBo that DS uses here that doesn't support quad?
I figured I'd get at least 3GB usable, and possibly all of it depending upon PAE (reports seem to vary). Even 3GB should work fine for me and avoid potential compatibility problems with xp64.
That said, I don't see a config option for XP x64.
John
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 9:22pm
SSDs have limited writes but on average use, they should last about 15 years... And try not to defrag them often or you will kill them quick =p
The 650i only supports the old 65nm CPUs such as the Q6600 or QX6850. The new 45nm ones such as the Q9300 or Q9450 aren't supported.
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 08 Jul 2008 at 5:47am
This leaves me a bit confused, as I trust what you say SkyR. I've read in more than one emagazine where they state that the new SSDs have a very long MTBF. What you describe is pretty much the way flash mem is and how the earlier cheap notebook drives were. I'd hate to think these "authorities" are passing on marketing hype that is total BS... Confused
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 08 Jul 2008 at 2:10pm
normal HDDs have a MTBF of ~1.2 million hours and SSDs have a MTBF of ~1.5 million hours. It's just there inflated measurement system just like contrast ratio for TVs. So take both with a grain of salt.
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 08 Jul 2008 at 2:45pm
Everything I have read pretty much backs what Sky said.
SSDs are great for data that gets written once and read lots.
There you simply can't beat it, the speed of access is incredible and as long as the files are not gigabytes in size the slower data transmission rates are not an issue really.
Multiple writes apparently are terrible for SSDs, reducing the viability of the memory chips faster than otherwise expected.
Dave
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
Gary View Drop Down
  Quote Gary Quote  Post ReplyReply bullet Posted: 08 Jul 2008 at 3:33pm
Just to give you some input here. I ordered and have had for 5 months now
  750i Case
  Quad Core Q6600
  680i LT Motherboard
  2 GB Corsair memory
  (1) EVGA 8800GTS 512mb video
  Creative Xtreme Gamer sound
  Corsair HX 620 PSU
  Stage 2 cooling
  XP Home SP2
This thing runs the heck out of any game i throw at it at 1920x1200 resolution.The only game that bogs it down somewhat is Crysis,but it is plenty playable.Machine is very quite and stable.We have 2 machines in our family at these specs and both run flawless. 1 thing i would suggest is to go with the quad core.You will be shocked at the power of these systems.My father and i both paid under $2000.00 for these systems.
Edited by Gary - 08 Jul 2008 at 3:38pm
