First Build
Post Date: 2008-08-15
drumdog20816 View Drop Down
  Quote drumdog20816 Quote  Post ReplyReply bullet Topic: First Build
    Posted: 15 Aug 2008 at 12:00am
Hi.  I would appreciate any thoughts on the following configuration.  I intend to use it for gaming - Fallout 3, Crysis, Mass Effect, Oblivion - photo editing, and general home office applications.  My monitor would be approx. 20 inches.  Please let me know if there are any areas for savings that will not affect performance too significantly for an amateur gamer.  I'm hoping to spend between $2000 - $2500.  Thank you.
Chassis: Antec 900
Power Supply: 750W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Quad Q9450 2.66GHz (1333MHz FSB) (12MB Cache)
Motherboard: Asus P5Q3 Deluxe WiFi-AP (Intel P45 Chipset) (Supports CrossFire)
System Memory: 4GB DDR3 Corsair at 1333MHz
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: ATI Radeon HD 4870 512MB
TV Tuner: - No Thanks
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 15 Aug 2008 at 12:49am
Nice config for your needs. If you do a lot of photo manipulation, you may consider an overclock of cpu and mebbe memory. If you want to save on rendering time that is. If so, I'd recommend going to at least stage 3 cooling for a good OC. Otherwise, it looks good! Thumbs%20Up
  Quote drumdog20816 Quote  Post ReplyReply bullet Posted: 15 Aug 2008 at 9:16am
Thank you for your input.  I appreciate it.  Big%20smile
  Quote drumdog20816 Quote  Post ReplyReply bullet Posted: 15 Aug 2008 at 5:54pm
Good thought.  I was torn over whether to go with two HDDs.  I think I will have a couple hundred dollars of flexibility in price, but would like to go economize where possible.  Would you suggest that the HDD running the OS be a faster one?
Also, would dropping the soundcard in favor of integrated audio be a mistake.  Thanks again.
  Quote drumdog20816 Quote  Post ReplyReply bullet Posted: 15 Aug 2008 at 5:56pm
You answered my question before I asked it.  You guys are good.  Thanks.Clap
  Quote drumdog20816 Quote  Post ReplyReply bullet Posted: 16 Aug 2008 at 9:40pm
Hi all - I was AFK for most of the day.  here is my revised build based on Harleyman's suggestions.  I think I will put a video card in myself to save a few $ and keep me within budget, unless you all think I'm making a mistake.  One final question, how significantly will OC'ing the processor affect its life if using Stage 3 cooling?  Thanks for all the feedback.  Smile
p.s - forgot to add 64 bit Vista to use 4 GB Ram
Chassis: Antec 900
Hard Drive 1: 160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: - No Thanks, I will be installing my own video card(s)
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 16 Aug 2008 at 9:50pm
Great basis for a killer system. Installing a GPU is pretty straight forward. If you know what power leads you'll need for the card, request those be run to where the card will be installed when it's built so it's as easy as plugging in the unit and powering up. Thumbs%20Up
