first custom build, please help
Post Date: 2011-09-14
keith View Drop Down
  Quote keith Quote  Post ReplyReply bullet Topic: first custom build, please help
    Posted: 14 Sep 2011 at 4:31pm
Hello; I have been thinking about this, and reading up for a little while on this.
Any help you could give me would be greatly appreciated, $3,500 is about the max I can dish out, of course less would be better as i still have to get the monitors etc.
would like it to boot up fast, load programs fast, possibly 2 monitors 23-27 inches]
[I need well rounded machine, that can play games well (while running other programs) , movies, edit video, format conversion of audio and video, web surfing and upgrade friendly,]
needs to be quiet, low profile lighting, room temp is around 75 degrees year round, floor is carpetd, I plan to put it on a wooded base
Saved Ticket #: 596797
[Please Type Here]
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Sep 2011 at 5:01pm
I'm assuming you know for a fact you need that much ram?
you need to change the cpu cooler to the a70 and you need to change your case, that case is for lced systems (real lc), for the config you have you want the haf x so that you have good airflow.
Here you go Ticket# 596824 --- $3,053 (To see this build click here)
Internet Access: Wireless PCI-E 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: ASUS PCE-N15)
Sound Card: ASUS Xonar Essence STX Virtual 7.1 (PCI-Express Slot Based)
Edited by DST4ME - 14 Sep 2011 at 5:02pm
