First DSO build help?
Post Date: 2012-01-26
falgorr View Drop Down
  Quote falgorr Quote  Post ReplyReply bullet Topic: First DSO build help?
    Posted: 26 Jan 2012 at 5:00pm
Edited by falgorr - 14 Apr 2013 at 10:25am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 9:57pm
for that res and games like bf3 you gonna want 570 but budget does not allow, to have quality parts you need to go with this:
Here you go Ticket# 648505 --- $1,972 (To see this build click here)
Motherboard: ASUS P8P67 PRO (Intel P67 Chipset) (New B3 REV 3.1 Revision)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache)
Video Card: 1x NVIDIA GeForce GTX 550 Ti 1GB (Includes PhysX Technology) (EVGA Edition)
Mouse: Razer Deathadder (Infrared 3500 dpi) (Gaming Mouse) (USB Wired)
this system is much faster then your config, however I want to change teh hdd and gpu but I can't due to budget.
  Quote falgorr Quote  Post ReplyReply bullet Posted: 27 Jan 2012 at 7:30am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 27 Jan 2012 at 8:51am
Hi falgorr...Until DST gets back to ya....
1.  The A70 is a great cooler and all you need. The D14 will fit but is bigger but is a little more quiet.  Keep the A70, IMHO.
2. The 1050W psu has a 7 year warranty, indicative of its quality, the 1200 DS has no stated warranty unless I missed it.  Stick with 1050W HX.  Plus you don't need 1200W.
Not sure, are you interested in sli in the future??  If not than you could drop the psu to 750HX and put that $100 towards a gtx560Ti, giving you a better gpu for gaming.
You said a little over $2000 was good, then I'd go with gtx 570 for another $150 or so over the gtx560Ti....
Good Luck Big%20SmileBig%20Smile
Edited by bprat22 - 27 Jan 2012 at 8:56am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Jan 2012 at 12:28pm
Ya what he said ^
1. a70 will give you great temps, no need for the d14 on the p67.
2. the ax/hx line of psu in corsair has a long track record of performance/reliability and the mentioned 7 year warranty, the DS psu we know nothing about and I think you looking at a 2 year warranty. I only recommend quality proven psus. Also as mentioned a 1200w is pointless in p67, what would you use it for? you can't do tri sli and that is the only reason to get a 1200w psu.
3. as mentioned if you don't need want sli ability then go with 750hx and save money and bump up the gpu, but I like to point out to you that jm299 says to play at your res he feels like sometimes he needs sli 570 for bf3, but then again we have people with single 570 that play bf3 at 1900 x 1200 and say they have no problems. so I just want you to keep in mind what jm299 said, I don't want you to tell me tomorrow that single 570 is not cutting it for you at your res and I should have told you to go with a sli able system. Personally I feel like you should be fine with one 570 at your res but I like to pass on all the info I know to you.
for a non sli able system check this out:
Ticket Number: 648690
but if you are looking at non sli system then check out ode 1, it cost a lot less but some parts are not as good as the config above and ode 1 would need mobo/psu change to do sli, above config just needs a psu upgrade, or if new gpus use little less power then the current ones the 750hx can do sli.
Edited by DST4ME - 27 Jan 2012 at 12:31pm
  Quote falgorr Quote  Post ReplyReply bullet Posted: 27 Jan 2012 at 3:13pm
Edited by falgorr - 14 Apr 2013 at 10:26am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 27 Jan 2012 at 4:24pm
Good Luck
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 12:12pm
Our pleasure and good luck
