First DSO build
Post Date: 2011-06-10
azdskin View Drop Down
  Quote azdskin Quote  Post ReplyReply bullet Topic: First DSO build
    Posted: 10 Jun 2011 at 5:48pm
I am looking to place my first DSO order within the next 30 days and I would like to know what your thoughts are.  I was going to get the ODE Level 4 but they changed the specs.  Below is what I came up with.
Chassis Model: Special Deal Hot Seller - Corsair 650D
Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Internet Access: Wireless-PCI N 300Mbps (Supports 802.11n/g/b)
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX Technology)
Extreme Cooling: H20: Stage 2: Corsair H70 Liquid CPU Cooler (High-Performance Edition)
Saved Ticket Number: 566760
Edited by azdskin - 10 Jun 2011 at 6:06pm
lucaslep View Drop Down
  Quote lucaslep Quote  Post ReplyReply bullet Posted: 10 Jun 2011 at 6:45pm
Great Config , Just change your cpu cooling option for a Noctua or Corsair a70 .
why?
these are the best for cooling solutions
and change your mobo to the p8p67 default or deluxe .
Edited by lucaslep - 10 Jun 2011 at 6:46pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Jun 2011 at 11:02pm
not good at all.
what res you gonna be gaming at and what is the budget?
  Quote azdskin Quote  Post ReplyReply bullet Posted: 11 Jun 2011 at 2:29am
I am new to gaming and not sure what all I need. As for my budget I was thinking $2500 to $2800.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jun 2011 at 2:54am
Ok then np, lets break it down, ok got the budget thank you, it will help me alot, now do you have a monitor that you will be using for gaming on this pc or are you looking for a monitor also?
  Quote azdskin Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 12:12am
I will have to pick up a new monitor also.  I really liked the ODE level 4 but when they changed the setup I lost interest in it.  I am not much of a gamer but I do like fast computers that will run what ever I throw at it.  I have an older dell XPS410 that is starting to show its age and was hoping to get into a nice custom build that I could hold onto for another 5  years.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 2:27am
Ok you are not a gamer then? so you want a powerful pc but not necessarily on the game front.
try this monitor:
Dell UltraSharp U2311H 23
and this pc:
Here you go Ticket# 567078 --- $2143 (To see this build click here)
Chassis Model: Special Deal Hot Seller - Cooler Master HAF 922
Motherboard: ASUS P8Z68-V PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Ask DS specifically for this fan to be added to the side, so you endup with 3 x 200mm fans:
haf 200mm non led fan
now this pc will give you decent gaming at that res and lot of power to do other stuff, only problem is that the 750w corsair is no longer in the config page and I don't trust the 750w DS certified as I don't know the real maker of the psu and it only has a 2 year warranty, so in short ask DS to use either the 750w corsair or if you want to be able to go sli, the 850w hx corsair.
ironmb View Drop Down
  Quote ironmb Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 2:29am
Well let's say you're going to go with the 1920x1080, these are roughly 22-24 inch monitors. Pending on what type of games you play at this resolution of your monitor, it will also inform us what type of GPU power you need. Some people just play MMO's.. usually one card can handle this, but some people want Crysis and Metro2033 at max settings with full AA.. which usually requires SLi 570+.
I'd go with a air cooler, while people are thinking Liquid Cooling is better than air.. it's really the same.. Liquid Cooling is a luxury unless you're running like 3 full loops (3 radiators, 3 pumps to break some benchmark records). The A70 Corsair is a very good air cooler.. and so is the DH-14 Noctua. They have actually better temps then the H70 corsair.
Edited by ironmb - 12 Jun 2011 at 2:32am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 2:32am
Just to clarify, LC is better then air, but stage 2 lc systems here are not real LC systems as in they give same/less performance as teh noctua and the A70, which is what ironmb meant when he said lc is not better then air.
but if you get stage 4 lc or higher you will get better temps, tho they are not needed, and as ironmb pointed out, it is a luxury and not a necessity.
  Quote ironmb Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 2:37am
I more-or-so went on the basis that he was picking the H70, the true liquid cooling loops that DS does on the stage 4+ will have better temps, definitely.
Edited by ironmb - 12 Jun 2011 at 2:38am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 2:39am
Ya I figured that, but was just clarifying for the op
  Quote azdskin Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 3:35pm
Thanks DST4ME for the great config. One thing I might change is the case.  I really like the 650D.  I have tried a couple of games on my dell but with the newer games it freezes up.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jun 2011 at 7:10pm
650d is a good case too, if you like that then that is the right case for you.
the gpus in the dell are probably not able to handle it.
