First Lumos Build, Feedback Please
Post Date: 2020-04-09
xps15z View Drop Down
  Quote xps15z Quote  Post ReplyReply bullet Topic: First Lumos Build, Feedback Please
    Posted: 09 Apr 2020 at 9:48am
This is my first build, I was debating between Lynx and Lumos with the same specs. Just not sure if there's an advantage to the Lumos case besides spending an extra $100. I also wasn't sure if I should upgrade to CORSAIR ML120 PRO instead of using the standard chassis fan.
I just need some feedback on what I have already.
I skip overclocking the graphics card since that's not needed.
I did select Overclock CPU - Up to 4.7GHz on All CPU Cores as it was free but not sure if it's needed.
Let me know your thoughts.
Motherboard: ASUS ROG Maximus XI Hero (Wi-Fi) (Intel Z390 Chipset) (Up to 3x PCI-E Devices) <br><strong></strong>
System Memory: 32GB DDR4 3200MHz Corsair Dominator Platinum DHX (Extreme-Performance) <br><strong></strong>
Power Supply: 850W Corsair / EVGA / Thermaltake (Modular) (80 Plus Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD (2TB Samsung 860 EVO) <br><strong></strong>
Storage Set 2: 1x SSD (2TB Samsung 860 EVO) <br><strong></strong>
Graphics Card(s): 1x GeForce RTX 2080 Ti 11GB (VR Ready) <br><strong></strong>
Cable Management: Exotic Cable Management - Blue - (Cable Combs with Custom Color Sleeved Extension Cables) <br><strong></strong>
Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) <br><strong></strong>
Airflow Control: - No Thanks
Boost Processor: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores <br><strong></strong>
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Priority Build: - No Thanks, 6 Week Ship Estimate After Order Is Successfully Processed
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Apr 2020 at 5:19am
A bit harder to comment since we don't know what uses you have for all that high-end gear.
The Lumos case, which is a Corsair Crystal 570X, is a bit larger all around. Longer, wider, taller by an inch or two. Tempered glass all around, which has your entire system on display. Whether you prefer that or not is a matter of taste. If you prefer the Lumos, it would seem a waste not to improve the look with some upgraded chassis fans.
As a personal choice, I prefer a lean and mean primary drive for OS, frequently used apps, browser, and maintenance software. Even several games will fit as well. I like the way all those annoying system scans are accomplished in seconds instead of minutes. A 512GB Samsung 970 Pro NVMe M.2 fits that description, and it's easily 5 times faster than the 860 EVO SATA SSD you picked.
The mild overclock is perfectly safe, FREE, and the chip is designed for it.
Assuming you know what you want to spend and why, that's all I've got.
