First OC'd system - Need general advice
Post Date: 2012-01-08
banjoman View Drop Down
  Quote banjoman Quote  Post ReplyReply bullet Topic: First OC'd system - Need general advice
    Posted: 08 Jan 2012 at 12:54pm
I'll be receiving my new system soon. Stage 1 oc on a 2600k in a haf x with extra 200mm top fan and a Noctua D-14 cpu cooler. It'll have dual GTX 570's so it'll probably build up a little heat in-game.
My basic question is this: For general everyday use is there anything I should look out for or be concerned about? I typically start-up the computer every morning and leave it running while I'm at work (just a few hours). I'm assuming the cpu or gpu's don't really heat up unless they're under load...
I've owned computers since '94 (and even built a few from scratch), but this is my first venture into oc land. Any general advice will be appreciated. :)
Thanks!
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 2:05pm
In my experience, if the OC is stable, and isn't crazy extreme (think LN2), then it is exactly like any other computer. Its fine to leave running like you normally would, etc. For general info, just check your voltages and temperatures, and if those are good under load, then your spiffy Big%20Smile
jmaster299 View Drop Down
  Quote jmaster299 Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 2:42pm
Just like you should do with any system, just control your room temps. Your system will run as cool as the environment it's in. If I keep my rig on but don't have either my door and/or window open the system will heat the room up. The higher room temp in turn makes the temp of your system go up.
That's even more important while gaming. Your system will pump out even more heat and you need to manage it.
  Quote banjoman Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 8:40pm
Thanks for the info. Does the system itself come with software to monitor voltage/temp or is it something I'll need to download?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 10:17pm
for volatge oc and etc CPU-z
for temps HWMonitor
to oc or set gpus fans MSI Afterburner
  Quote banjoman Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 10:58pm
Thanks DST4ME I'll check 'em out.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Jan 2012 at 11:11pm
My pleasure and good luck
This page was generated in 4.785156E-02 seconds.
