First Time Build, How does it Look?
Post Date: 2008-07-07
Whackywombat View Drop Down
  Quote Whackywombat Quote  Post ReplyReply bullet Topic: First Time Build, How does it Look?
    Posted: 07 Jul 2008 at 2:09am
Hey guys this is my first time building myself I Gaming-Rig. This is mainly going to be a gaming rig but I still want to be able to do college work such as typing essays and like. I am attempting to keep my price range under 3,500$. I was wondering if anyone could please critique my build, this is what it looks like so far:
Chassis: Digital Storm 850Si
Power Supply: 750W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Duo E8500 3.16GHz (1333MHz Front Side Bus) (6MB Cache)
Motherboard: Asus P5Q3 Deluxe WiFi-AP (Intel P45 Chipset) (Supports CrossFire)
System Memory: 4GB DDR3 Corsair at 1333MHz
Card Reader: - No Thanks
Hard Drive 2: 250GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Video Card: 2x CrossFire Dual (ATI Radeon HD 4870 512MB)
TV Tuner: - No Thanks
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Modifications: - No Thanks
Windows OS: Microsoft Windows Vista Home Premium
Protection: McAfee Internet Security (Includes: AntiVirus, FireWall and AntiSpyware)
Office: Microsoft Works Suite 2006 (Word, Streets and Trips, Money, Works 8, Encarta
By the way, I was wondering what your guys thoughts on the Acer 22inch monitor are?
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 4:33am
It looks solid. Make sure your operating system is 64 bit if you want 4GB of RAM installed.
I personally feel there are better programs than McAfee for security. SkyR turned me on to ESET Security Suite and I have been very pleased. I have used both Symantec and McAfee in the past, and will say ESET has both beat soundly.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 8:36am
looks good to me, i think the only thing id change is go to a single 500gb HD
that and make that other optical a lightscribe too, reason being that the newer SATA cable is more flexible and air-cooling efficient. it would be a couple bucks well spent
as far as the acer, i believe that you can find some very nice monitors for that price and you get to be more picky if you shop on your own. But since we dont get a link to the exact monitor its hard to say...
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 11:51am
I am in the same boat as ender on this one, Acer and I have never gotten along. You would be better off getting a monitor you can look at and see that you like at a local electronics outlet. Buying a monitor sight unseen is a poor choice in my book.
As far as brands, I would look at Samsung, I also have found HP and LG to be pretty good depending on the model number.
The others I have tried include Dell (yuck), ViewSonic (double yuck) and Sony, ok but pricey.
Dave
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 12:02pm
I have a Westinghouse 22" LCD and while the controls are a bit odd, the performance is good.
Bismark View Drop Down
  Quote Bismark Quote  Post ReplyReply bullet Posted: 07 Jul 2008 at 4:31pm
Ive had good luck with Gateway monitors, still running one thats almost 8 years old and got a new one from them recently.
Asus Rampage Formula
Core 2 Quad Q9550
2 ATI Radeon HD4870 Crossfire
4GB Corsair DHX 1066
1000W Corsair HX
DS 850Si
