First true gaming pc buildPost Date: 2010-09-20 |
theploeg
Newbie Joined: 10 Sep 2010 Online Status: Offline Posts: 6 |
Topic: First true gaming pc build Posted: 20 Sep 2010 at 9:53pm |
hey this is my first real gaming build and i am hoping to get some advice on this build.
System Configuration:Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 950 3.06GHz (Quad Core) Motherboard: ASUS Rampage III Extreme (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition Highly Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 3x SLI Triple (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: Standard Factory Heat-sink and Fan H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended) Graphics Boost: FREE: Yes, Overclock the video card(s) as much as possible with complete stability Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Pre-Install Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Grey (Large) Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty any help would be greatly appreciated. |
dblecircle
Newbie Joined: 30 Aug 2010 Online Status: Offline Posts: 80 |
Quote Reply Posted: 20 Sep 2010 at 10:24pm |
There's a bottleneck via the harddrive. I'd drop the 3rd 480 and get an SSD. You also should get something besides the stock cooler if you are going to overclock, which, getting the Rampage III I assume you want to do.
Just some quick observations
980x @ 3.9, SLI Dual 480s, 120 gig SSD, X-fi Champion, 1200w, 800d, 12 gigs RAM, RTS + CS5 Fun O Fun Oh My! |
!ender_
DS Veteran Joined: 24 Oct 2007 Online Status: Offline Posts: 4219 |
Quote Reply Posted: 20 Sep 2010 at 10:25pm |
you definitely need a processor cooler
what makes you want the REIII over the evga SLI3?
1200w might be pushing it too far if you want to overclock those video cards.
theploeg
Quote Reply Posted: 20 Sep 2010 at 10:34pm |
Which cooler should i take for the processor. Also i have an SSD at home to install quick. Also over clocking will come in time and i am wondering if the 1500w will run on a house hold circuit.
!ender_
Quote Reply Posted: 20 Sep 2010 at 10:52pm |
noctua u12p and yes it will but the cable is unique to the power supply so you cant ever lose it
theploeg
Quote Reply Posted: 20 Sep 2010 at 11:20pm |
Thanks also will i keep the fans off the haf x or will they removed for the water cooling
!ender_
Quote Reply Posted: 20 Sep 2010 at 11:25pm |
i dont understand the question
theploeg
Quote Reply Posted: 20 Sep 2010 at 11:56pm |
sorry will the original fans hat come equipped with the Haf X still be mounted or is it just the cooling pump
!ender_
Quote Reply Posted: 21 Sep 2010 at 12:29am |
you didnt select water cooling here
but if you did, the case will keep most of its original fans, it depends on where they put the radiator/what size/how many you get
theploeg
Quote Reply Posted: 21 Sep 2010 at 9:44am |
okay thank you
MagiK
DS Veteran Joined: 25 Aug 2010 Online Status: Offline Posts: 1074 |
Quote Reply Posted: 21 Sep 2010 at 1:41pm |
In answer to Ender's Question about the REIII.....the RE III has way cooler little doodads added the ROG connect etc. I also like the color scheme and the board layout. Is it worth the extra $$$ ...thats up to the buyer. (I also think it is better for OC..but that is just a theoretical opinion as Ive never actually owned one)
Edited by MagiK - 21 Sep 2010 at 1:44pm |
theploeg
Quote Reply Posted: 21 Sep 2010 at 7:16pm |
okay so i added the extra pump resovior for the processor and given it a 1500 watt power supply. Anything else and yes i know 500 is small but i have 2tb and 120 of ssd at home so i am safe with storage for now.
al3xLJ
Groupie Joined: 29 Aug 2010 Online Status: Offline Posts: 217 |
Quote Reply Posted: 22 Sep 2010 at 3:06am |
post updated build
