FrostChill Cooling System
Post Date: 2011-11-11
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Topic: FrostChill Cooling System
    Posted: 11 Nov 2011 at 3:27pm
I've noticed that no one recommends it...is it not worth the $160.00.
Thanks
FR3SHM3AT View Drop Down
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 3:43pm
I have it. Heres what it looks like.
But If I had to do it all over again would have went stage 4 for the compression fittings. Ive had no issues but compression fittings look real good.
Still loving my beast though.
Edited by FR3SHM3AT - 11 Nov 2011 at 4:01pm
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 4:07pm
FrostChill is worth it, but it has a nich. Typically, $2600 to $4000 price range. After that, TEC-Chill, before that, air cooling.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 4:26pm
This is what I'm looking at...
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: 320 Series)
Video Card(s): 1x NVIDIA GeForce GTX 570 2.5GB (Includes PhysX) (EVGA 025-P3-1579-AR)
H20 Tube Color: White Tubing with High-Performance Fluid (UV Lighting Reactive)
Game: FREE: Batman: Arkham City (Available only with NVIDIA GeForce GTX graphic cards)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 4:36pm
1. you dont need LC at all.
2. if you want lc go with stage 4, frostchill does not have the good components (good wb and rad).
your config is not giving the best performance for your money and hailstorm does not have great airflow at all.
what res you gonna be gaming at and the games you play do they utilize sli correctly?
what was the price of that config you posted?
Edited by DST4ME - 11 Nov 2011 at 4:37pm
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 5:16pm
Digital Storm Desktop 317710
$2777.00
COD, and video editing.not sure of res.
I really like the look of the Hailstorm and the assassin.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 7:05pm
for about $130 more you can have sli 570, much much better psu, a case with proper airflow, with sli in hailstorm you are not gonna have great airlfow.
at the end for around $3000 you can have sli 570 and all:
Here you go Ticket# 615967 --- $2,991 (To see this build click here)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 2.5GB (PhysX) (EVGA 025-P3-1579-AR)
this system will have better load temps cause the case has much much better airflow.
now if you do this exact config with hailstorm/assassin you will be paying hundreds more for no performance gain, if anything you pay more and lose performance.
You never told me the native res of your monitor, I need to know that, otherwise I'm just recommending the dark. The entire build of the pc is around the res of the monitor, if you are looking for a monitor then we need to nail that down first, otherwise we wont' know if you are wasting money on 2.5GB version of 570 or not, if you even have use for sli or not, etc.
Edited by DST4ME - 11 Nov 2011 at 7:06pm
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 8:45pm
right now I have a res of 1600 x 900 but will be upgrading to 1920 x 1080
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 9:25pm
for 1900 x 1200 if you are planing on maxing out games like bf3, my config is twice as powerful as your config in gaming and games like bf3, you won't be running bf3 in max setting with good minimum fps with a single 570/580, but sli 570 will do it. However the 2.5GB version of 570 is not needed, but the price difference is not much, if you like to save money go with 1.2GB version of 570 sli.
for 1600 x 1200 a single 570 is more then enough and the 2.5GB version is a waste.
Edited by DST4ME - 11 Nov 2011 at 9:26pm
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 10:31pm
thanks for your help, it's really helped.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2011 at 11:41pm
My pleasure and good luck
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 12 Nov 2011 at 3:47pm
do I ask ds to add fans (are they available in red :)?
what do you guys think of the NVIDIA case?
Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Nov 2011 at 4:06pm
I personally don't care for the nvidia one but its cool, it has green fans, problem is that there is no oem 200mm green led fan to add to the optional top, they come in blue or red.
you want to tell DS to add a "oem 200mm red led fan" to the optional top slot.
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 13 Nov 2011 at 4:15pm
yet another question :).
why the Corsair A70 Dual 120mm Fans High Performance Cooler and not the Digital Storm Vortex Liquid CPU Cooler?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Nov 2011 at 6:46pm
Because the a70 has better performance, a70 and noctua are king till you get to stage 4 lc.
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 13 Nov 2011 at 6:57pm
thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Nov 2011 at 7:02pm
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 15 Nov 2011 at 2:31pm
what are your thoughts on the Dell UltraSharp U2410 Monitor
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Nov 2011 at 6:22pm
I have one and love it, its last years model, this years model:
Dell UltraSharp U2412M
flex View Drop Down
  Quote flex Quote  Post ReplyReply bullet Posted: 15 Nov 2011 at 8:25pm
Thanks again for all your help, just ordered the monitor and will order the pc ( your build) on black Friday. I'm from Canada and every little bit will help as the shipping is $250.00
All good:)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Nov 2011 at 10:21pm
