Future upgrade and GPU Cooling Question
Post Date: 2010-09-07
goodman247 View Drop Down
  Quote goodman247 Quote  Post ReplyReply bullet Topic: Future upgrade and GPU Cooling Question
    Posted: 07 Sep 2010 at 8:12pm
Hi, I have a question regarding GPU cooling. Is there any easy to install and good GPU coolers available for the GTX 480 card? Also, in the future I hope to add another 480 card into my rig, should I opt for a higher power supply now or buy a new one when I upgrade? I placed the order last Friday and still in stage 1.
Thank you
My configuration:
Processor: Intel Core i7 950 3.06GHz (Quad Core)
Motherboard: EVGA X58 SLI 3 Edition (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s) (Model: 131-GT-E767)
Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Video Card(s): 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended)
Pre-Install Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card
Warranty: FREE PROMO: Life-time Expert Customer Care with 4 Year Limited Warranty
  Quote Alex Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 8:23pm
For a second GTX 480 it is recommended to go with a 1000W PSU. Also, you won't need any GPU coolers with the chassis you selected.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 8:43pm
good keep in mind that non liquid aftermarket gpu cooling tends to keep the warm air in your case, a wonderful idea since its usually aimed straight up at your processer.. the stock cooling on the fermis is plenty good
id probably go to a 1200w psu for 2 480s
dont by a new one when you upgrade or youll have to strip and redo the entire case AND have a PSU just sitting around
  Quote goodman247 Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 8:54pm
I see, then is it still possible to make the changes to my rig even though I'm already charged?? Also, can the dual 480s last for at least a few years without any after market cooling?
Edited by goodman247 - 07 Sep 2010 at 8:57pm
dranza View Drop Down
  Quote dranza Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 9:13pm
Yes its still possible to make changes to your rig. As long as you don't go trigger happy and overclock it to much there shouldn't be any problem for it to last at least a few years and if you don't mind the noise you can set the fan on manual to 100%, it will help to keep it cooler
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 9:21pm
goodman they definitely can, they are warmer than the market is used too, but they cool themselves well even without changing the fan, and better if you do use it, just a little extra racket at high load times
  Quote Alex Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 11:02pm
We can still make the changes. If we've already built your system (Stage 4 or Stage 5) then we will have to charge you a small re-build fee of $35 to take apart the system and another $35 to re-build it.
  Quote goodman247 Quote  Post ReplyReply bullet Posted: 07 Sep 2010 at 11:49pm
I see, now I'm struggling if I should get the 2nd 480 now or wait a bit later and install it myself. But I'm not sure if I can do it on my own...
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 12:01am
just keep in mind that if you install it yourself if wont be under warranty, at least not DSOs warranty.
and you probably wouldnt save too much money either
as far as installing it though.. its stupid easy, i mean.. if you can put a disk in a disk driver and screw in a 1/4 inch screw, youre most of the way there, the rest is just being careful.
Scorp View Drop Down
  Quote Scorp Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 10:07am
Would two GTX480s do fine with regular HAF X cooling fans or would a liquid cooling / better fan system be required?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 10:37am
yea the cards pretty much cool themselves, as long as you have a cool air source and the hafx is open air and plenty of room for them to breathe in there. you never need liquid cooling it just does a better job than air cooling
  Quote Scorp Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 10:38am
Thanks! :D
MagiK View Drop Down
  Quote MagiK Quote  Post ReplyReply bullet Posted: 08 Sep 2010 at 10:55am
Remember the difference between "need" and "want"  ;)  These guys give the best advice.
