Future video cards' power/PCI requirements
Post Date: 2008-11-14
hotcakes22 View Drop Down
  Quote hotcakes22 Quote  Post ReplyReply bullet Topic: Future video cards' power/PCI requirements
    Posted: 14 Nov 2008 at 2:05pm
Do you think that as time goes on GPUs will require bigger PSUs and more slots? For example, the 4870 X2 required, I believe 2 slots and something like a 650 W power supply. Will it be possible in the future to use such a card in 1 slot and with less power?
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 2:34pm
Most performance cards have dual slot coolers. However this might change in the future as AMD is developing a VCT solution for their cards.
As time goes on, the manufacturing process gets smaller so GPUs in the future will either use the same amount of power as they are now and be twice as powerful or use less power and be just as powerful.
Every card today uses less than 300W. Most of them usually under 150W on max load.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 3:18pm
I think the power consumption will go down but when that is going to happen I'm not sure.
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 3:23pm
there has been some rumors/ideas that possibly in the future the GPU will be totally seperate from the computer(in a different case)
MyThLoSt View Drop Down
  Quote MyThLoSt Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 4:31pm
ati is already making something similar  to that idea for laptops.
check it out
http://ati.amd.com/technology/xgp/index.html
