general questions as well as system critique $3K
Post Date: 2008-08-18
rai-zero View Drop Down
  Quote rai-zero Quote  Post ReplyReply bullet Topic: general questions as well as system critique $3K
    Posted: 18 Aug 2008 at 10:01pm
I'm a type of gamer who likes to try the newer (good-looking games). I'd like to be able to play Q4, Bioshock etc. as well as what will come in a couple out this year or next.
I don't need any killer system, but something that's very good with todays games and could possible be good for a few years.
My current computer is old.  I have been doing OK can play most games but needless to say not up to the eye-candy I'd like.  I currently have 6 year old P4 with 512K RAM Win XP.
I don't like to tinker with my rig, so while I could open up the case to add a HD or such, I prefer not to.  So I like to be more or less not looking to replace the video cars in 6 months etc..
As such, I would like to get something all around good and keep it going a while.
This is a reason I like DS seems to have great warranty and support.
couple general questions my system budget ~$3K and this is kind of firm, this price for the whole deal including a monitor.  I was going for 24" monitor but don't have to.
I asked DS support for what they would say for $3K and they gave me an Athlon (seems to be lesser than Intel)  with $735 in video cards.
I don't say this is wrong, but to me with the new ATI cards cost half that I'd rather put the money into the whole system not just in the video cards.
here is the DS suggested system they gave me - http://www.digitalstormonline.com/comploadsaved.asp?id=174901
my few questions:
what type of RAM and how much?  I know there is a lot of different speeds but what's the best bang for the buck?[
What's the idea get a faster dual-core or a slower quad-core? (again bang for the buck)
How is the new ATI Video cards?  I read they are near best for considerable less money.
Why is DS price some video cards over $600 like nvidia 280 when the real price is nowhere near that?  There has been consederable price drop but DS is not close to what it could be.  I know they have to make some profit but seems like the price of the VC is a big place to cut hundreds of dollars especially with the ATI having great performance for low $300s.
I don't think I want overclocking since longevity is a big plus for me, I'd rather keep more stock.
here is one build I am thinking but could change if you think I'm off.  -- http://www.digitalstormonline.com/comploadsaved.asp?id=176318
note: I see my posted system is $3121 so over my budget but that's OK, I could go lower if you think I can drop something or a bit higher but this is the ballpark price.  Note my system has 2 HD (500G x2) and my system has 2x as much RAM as the DS proposed system had just one HD and 2G RAM so that's most of the price difference.
Edited by rai-zero - 18 Aug 2008 at 11:13pm
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 12:34am
First, I would like to point out that AMD processors have taken a lot of heat from bad publicity really. The particular cpu that DSO recommends with that mobo with the 790 FX chipset will actually perform slightly better than what your config has. AMD has a simple OC program that you can use to do mild OC or go with more aggressive settings at your option. For this config, I've seen where most people are getting good, stable OCs from 3.4GHz to 3.6GHz easy. Those who are cautious types have been going  with around 3.2GHz with simple air cooling. I would recommend stage 2 cooling for any quad core really BTW.
The new ATI cards are stunning. To be honest, you could go with an HD4870x2 and save a bit of cash and get slightly better performance. That is the current state of the art card.
If you want to run with more than 2GB ram, I would recommend going with Vista 64-bit OS so that it can be utilised. Otherwise it's just wasted. I don't mean to sound biased, but I just wanna show you the other side... why DSO made their recommendations. Both configs are really nice really. You can always juggle things around some to suit your desires... 2 HDD, more ram... provided you change your OS to 64bit, etc. If you must drop something to get 2 HDD like you desire or more ram and vista 64bit, consider dropping the sound card first. While it's a good sound card, it probably won't affect your gameplay as much as the other components.
As far as pricing of their components, it's unfortunate that nVidia dropped their prices after many pc builders bought their initial stock. Average consumers saw an immediate price drop because nVidia covered them, but did nothing for the builders. So they have to sell the parts at the original price plus the testing and labor involved. Don't forget that portions of any build include the guarantee of a strong 3 year warranty.
P.S. Mild overclocks are fine. AMD has stated that one reason they brought out their new OC software was to reassure the consumer that their products are reliable and are able to run faster and still remain stable (safe and reliable).
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 1:56am
I guess the first thing I would say, is that the video cards should not be views as "just" add-ons. I know, back in the days when graphics cards were new, that was the perception we all had. They were something you added to a system, but the main show was still the CPU. Today that is no longer the case and for a gaming computer, the graphics cards should be viewed as more important than the CPU- crazy reversal there huh?
If you choose wisely, they can get you years of enjoyment, depending on what you are willing to live with in terms of performance as the cards age. The 8800GTX was released in November of 2006. We are only a few months away from the second anniversary of the release of those cards, and a pair of 8800GTX will still any game other than Crysis at maximum details and provide amazing framerates, and they still hold their own even there. The 8800GTX is only now begining to show it's age, and will still most likely be able to handle most titles with ease for at least another year. Not too shabby. Based on what I see right now, I am going to guess the longest legs will be on the GTX280, although the 4870x2 isn't a bad card either. I believe the most powerful single GPU solution will prove to have the greatest longevity however.
Having said all that, I think you'd be sorely dissapointed with the second build you listed. The card you have selected is decent as a single card, but will be stressed to run some games at that 1920x1200 resolution you have decided to go with. The sweet spot in terms of budget is definitely a 22" monitor, but, I tried to come up with a system that would make use of an Intel CPU, a 24" monitor and hopefully provide that longevity you're seeking.
I see your budget may not be quite as strict as I thought after first reading your post, so I will also offer up this system:
The inclusion of a 1000W PSU in both of these configurations will allow you to add a second GTX280 at some point in the future. I would suggest the second config if the price isn't past you pain point. The CPU is a little stronger and when overclocked, should be able to keep even a pair of GTX280's fed with frames to render.
Edited by Tyler Lowe - 19 Aug 2008 at 2:06am
  Quote rai-zero Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 8:34am
Tyler,
I don't understand OC.  I guess it's getting a faster CPU or the cost of a 2.5 mhz.. sounds too good to be true.  I keep thinking there's no suich thing as a free lunch.
does this make the CPU unstable or prone to early failure?
what clock speed would a 2.5 chip be with the DS OC?   Just so I can have an idea what to expect.
thanks
Edited by rai-zero - 19 Aug 2008 at 8:35am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 8:43am
Originally posted by rai-zero
Tyler,
I don't understand OC.  I guess it's getting a faster CPU or the cost of a 2.5 mhz.. sounds too good to be true.  I keep thinking there's no such thing as a free lunch.
thanks
Its not a free lunch, at stock the chip is not running any where near what it can run at, so you can take a 2.5 and go upto 3.0 atleast.
this is the biggest difference between Intel and AMD, Intel chips can run much faster then the stock speed they are sold at.
so all you are doing is making it go faster but no where near where it would hurt the chip.
the whole point of places like DS and other places is that they will sell you an overclocked PC with warranty, so if something does happen you are covered.
but to answer your question of stability and failure, no, DS tests the system extensively before they send it to you, they make sure the OC speed is stable and no failures. Once they have a stabled OC-ed PC, then they ship it to you with up to a 4 year warranty on it.
I just like you didn't like OC either and was misinformed about it and that it could hurt the chip. But after reading about it and talking to people who know about, I understood what I explained to you at the beginning of this post.
Hope that helps ;).
staf111 View Drop Down
  Quote staf111 Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 10:56am
Here's how I would modify the DS rig sent to you. The power supply and motherboard are fine but I would consider downgrading the prosessor because you will see minimal improvment for your $99 (maybe 8%). Also, for cooling the antec works much better then the Si 750 and this upgrade will be a better bang for the buck than the stage 2 cooling (although it will be a little louder).  For RAM, I think 4Gb would be best but you can upgrade that yourself later if you want.  For the GPU, since one 4870 will probably run any current game fine for now, I would consider simply getting one now and upgrading later and at a lower cost.  I have always been told that speakers are more important than a sound card so I would consider getting a cheaper sound card and more expensive speakers. Last, if you have time shop around for a monitor.
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 12:03pm
Tyler,
thanks
I know, it seems too good to be true. But you do pay for the performance increase in a round about way. We tend to lose track of the additional costs involved with overclocking, because DSO's system components have been selected with OC in mind. The improved CPU cooling, as well as improved case cooling influence your overclocking results as surely as selecting the right RAM, power supply, and motherboard for the task. All of the groundwork is already laid out for at least a moderate overclock before you even clicked on the "customize now" link.
As far as the final number you can expect, this depends on a few things.
The power supply's ability to provide clean, ripple free power to the motherboard, is the basis for a good overclock. DSO has selected only quality units, so this part is easy enough. just be certain your power supply is not stressed to output too close to it's rated power by your other selections to avoid problems. Any of the above selections will be fine in this regard.
The system RAM and motherboard will be a factor in how high a system clock you are able to achieve. This is the only area in my second build that gave me pause. I would have prefered the higher binned RAM (1066 MHz) over the stock 800 MHz DDR2, as it does tend to overclock a bit better. The motherboard is the heart and soul of your system, and will have a huge impact on overclocking results.This is why I selected the 780i in the more expensive build.
Finally, we come to cooling. Increasing operating speeds and system voltages increases the temperatures everything in the system must operate at, and creates additional waste heat that must be removed from around system components in order to ensure the best, and most stable possible operation. This is where your case and the quantity and quality of your case fans comes in. The Antec 900 provides very good cooling, the 850i provides *superb* cooling.
Overclocking is not an exact science, but as far as what I would expect, depending on many factors including "luck" with a specific batch of CPU's:
Q9300: 3.0GHz to 3.3GHz
Q9450: 3.2GHz to 3.6Ghz
These are results I have seen "on average". Exceptional results can push the Q9300 above the numbers I placed at the high end of the range for each chip, but I want to stress that is not typical. The better the components you place around the CPU, the higher in this range you will find yourself on average.
In terms of the life expectancy, bear in mind the conditions most CPU's labor under. Stuffed inside a cramped, OEM case made from solid plastic and steel (great insulators), with large, flat IDE cables stuffed in where ever they will fit, obstructing air flow, and maybe a single 80mm fan cooling the whole mess. The operating range specified by Intel takes this into account. By selecting aftermarket cooling, and a greatly improved case to build in, you stack the factors that eventually kill a CPU in your favor greatly. Even overclocked, these systems may operate well under a typical OEM (HP, Dell, etc) system at "stock" speeds.
The impact on longevity is negligible if the overclock is done correctly. Intel basically "overclocks" their higher end chips at the factory and charges you more for it, all you are doing is unlocking the true potential of their chip. The money you pay is for a professional to overclock your system, and to test that overclock. Additionally, should you have problems with any of those settings in the future, not only are the physical components garanteed for a period of 3 years by default, and more if you want to pay for it, but you have *lifetime* technical support. If, for whatever reason, you start seeing instability, help to find the problem, and to correct it is a phone call away to US based expert support.
Hopefully this answers all of your questions, but if you have more, please,ask away. There are lots of extremely knowledgable and helpful DSO customers on these boards that love to provide input, in addition to goofballs like me, and the DSO staff also cruises these boards to ensure that advice is accurate and all questions have been answered.
Edited by Tyler Lowe - 19 Aug 2008 at 12:08pm
  Quote rai-zero Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 12:30pm
thanks again
what about OC of RAM?  I noticed you didn't specify OC of the RAM is that less important than the CPU?
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 12:58pm
Harleyman has it. The overclocked RAM selection does include a RAM cooler, which will influence your final overclock. I think it is less important than putting that same money into an improved case for instance, but if you already have something like an 850i, and 780i motherboard with stage 3 cooling or better selected, and don't mind spending the money, selecting the RAM OC can squeeze a touch more out of your overclocking results. I would put budgeted money towards any/all of those other items before even considering selecting the RAM overclock.
Edited by Tyler Lowe - 19 Aug 2008 at 12:58pm
This page was generated in 0.1010742 seconds.
