GPU problem, please help
Post Date: 2022-06-13
Jcc1989 View Drop Down
  Quote Jcc1989 Quote  Post ReplyReply bullet Topic: GPU problem, please help
    Posted: 13 Jun 2022 at 7:48pm
So, I bought a GPU from a friend of mine, it was a RTX 2080 TI he sold me for $500 after he upgraded to the RTX 3080. It's been working great had no problems for a while until I use the MSI After burner OC scanner. After I was done I tried to run a game, it ran good until the GPU you reached 81゚ My 2 monitors went black and I can still hear the game play, But the PC is completely unresponsive I have to manually shut it down, As if the GPU was removed while the PC was running. I have no warranty for it and have no clue where I can get it fixed or what's wrong with it, Would like to not spend $1000 for a new one.   Please help thank you
  Quote Cretae Quote  Post ReplyReply bullet Posted: 14 Jun 2022 at 3:25am
Start by undoing whatever MSI Afterburner did. First step when something you did changed your performance is to undo it. I'd guess your card is thermal throttling, but it shouldn't at 81C. It may have spiked a temp you didn't see.
You'll get a lot more eyes on this in "Technical Assistance" above.
Edited by Cretae - 14 Jun 2022 at 3:28am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Jun 2022 at 11:18am
Responded to this under Tech Assistance. Pretty much what Cretae said.
Good luck.
Edited by bprat22 - 14 Jun 2022 at 11:20am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 16 Jun 2022 at 4:09am
