grapic card temps
Post Date: 2008-08-27
brian View Drop Down
  Quote brian Quote  Post ReplyReply bullet Topic: grapic card temps
    Posted: 27 Aug 2008 at 6:31pm
hi, Here are my specs
750i MB
8400 Cpu (stock speed)
2 gig of 1600 ram (stock speed)
2 8800GTS (512mb)  SLI
650watt  Antec PSU
Antec 900 case with optional fan on side.
So my question is after I play a game for about an hour I look to see my temps (mainly my graphic cards).  I think they are high..... between 65-75 degrees.  Is that normal?  The puter is on the floor with thin carpet, but would that matter?  I have speed fan, but really have no clue on how to config it to work for me.  Ever fan is working and blowing out in the correct way.  top is blowing out, 2 front are blowing in, the side is blowing in and the rear is blowing out.  I know the Antec is small when you put 2 8800gts in it and there isnt much room with all the cabling, but could that really be the problem?  All the fans are on high (set y me with the fan controllers)
Mason,  do you have any suggestions?
Thanks guys
Brian
Antec 900 case
Nvidia 750i FTW Motherboard
Zalman 9500 CPU cooler
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 27 Aug 2008 at 9:24pm
75C is normal.. nothing to worry about until temps get to 90C.
Nickdapimp View Drop Down
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 27 Aug 2008 at 9:44pm
Yeah those temps are normal as is. Did you overclock them?
Randy View Drop Down
  Quote Randy Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 1:25am
Those temps are fairly normal. Increase your fan speed with Nvidia ntune or rivatuner. By default the driver sets the fan speed to 25% which is really low. I would recommend upping the fan speed to 80% if not 100% while gaming. You will achive much lower temps than that.
PS. Rivatuner owns all. But its fairly confusing the first time using it.
Edited by Randy - 28 Aug 2008 at 1:26am
Intel E6750
2gbs 800mhz Ram
8800 gt oc 660/1900
320gb hd + 500gb
Dual boot - Ubuntu 8.04, Xfce, Compis-fusion & Windows 7 Ultimate x64
  Quote brian Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 3:23am
thanks all, no my cards are not overclocked, but kinda interested to see if I can get them working better.  I will try that program mason..
I do have one more question, I have 2 8800 gts.... what is a good overclock for those?
Antec 900 case
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
  Quote brian Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 8:16am
thanks, the program works very good to increase my fan speed.
Antec 900 case
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
  Quote brian Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 8:25am
true...no need to oc my SLI.  FS9 is going good.
Antec 900 case
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
  Quote brian Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 8:26am
that is the southern california scenery
Antec 900 case
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
  Quote brian Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 7:45am
im not sure who makes the plane, Thanks mason for the program.  totally works great.  I can see before me the temps dropping.
Antec 900 case
8400 3.6
2 gig of 1066 ram
1 Evga GTX 465
24" Samsung LCD
3DMark06= 17,360
