>>Help with my setup please<<
Post Date: 2010-05-19
clmelement View Drop Down
  Quote clmelement Quote  Post ReplyReply bullet Topic: >>Help with my setup please<<
    Posted: 19 May 2010 at 11:40am
So i play mostly WoW nothing crazy, but i'd like to run it at top specs.
2000$ budget
1)Could you please make any suggestions of what should be upgraded or where i should put my money? I was told GPU, CPU, and HDD were important. I got 2 HD's with a raid 0 setup which i don't fully understand. i'd appreciate it if someone explained how it would affect my computer or if i should just get 1 HD.
2)I'd like to know if i need a better PSU for my hd 5870 1 gig and if my cooling sysyem is ok.
3)lastly, is this setup going to kick ass or fail horribly?
thanks in advance for any advice given, i appreciate your help
-chris
here's my setup:$1859.00
Chassis: CM storm scout
CPU: Intel i7 930 2.8GHz (quad core)
Motherboard: EVGA x58 micro edition
System Memory: 6GB DDR3 1600 MHz Digital storm certified Performance series
Power Supply: 750 watt digital storm certified
Hard Drive Set 1: 2x (1.5TB seagate barracuda 7200 rpm)
Raid: HD 1 set to raid 0 config
Cooling: h20 stage 2 - asetek liquid cooling (120mm radiator)
Chassis Airflow: standard
OC: 3.3 to 3.9 (as it suggests)
Herniter View Drop Down
  Quote Herniter Quote  Post ReplyReply bullet Posted: 19 May 2010 at 2:41pm
What resolution will you be playing at?
1) Raid 0 will not give you any performance increase in WoW.  3TB of space seems a bit exctessive unless you have a ton of Blu-Ray/DVD rips.  1 HDD would probably be antiquate.
2) a 750w PSU will easily support that setup, xfire in the future will not be possible without upgrading to a bigger PSU.
3) It should run WoW in 90% of situations with max graphics / AA at resolutions lower than 1920x1200.
Change your cooling to Noctua it will cool far better than the Astek liquid cooling you have chosen.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 May 2010 at 1:22am
we need to change a few things but first we need to know what resolution you will be playing at.
  Quote clmelement Quote  Post ReplyReply bullet Posted: 20 May 2010 at 1:48pm
probably over 1920x1200. i can't tell atm because i just ordered my 22 inch AOC and haven't been able to look at the different resolutions
  Quote clmelement Quote  Post ReplyReply bullet Posted: 20 May 2010 at 1:49pm
i got the noctua cooler upgrade and dumped the raid 0 after looking into it thanks for the advice. noctua is a much better choice as you suggested
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 20 May 2010 at 7:30pm
change 930 to 920 to save a few bux and change the 750 to corsair brand. i think you should get a smaller HDD even if u want two i think 2 1TB's is enough
Mr.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 May 2010 at 2:50am
Here you go Ticket# 408327 --- Price: $2003 (To see this build click here) Price after current promotion $2003
Trim Accents: - Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
  Quote clmelement Quote  Post ReplyReply bullet Posted: 21 May 2010 at 11:34am
thanks for the setup and all the replys i'm confident in what i've ordered now
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 21 May 2010 at 1:33pm
congrats dst's build is solid. this computer has room to grow in the future... so when it is time to upgrade send it back and change what needs to be changed. it is much cheaper then buying a new one.
one thing you may want to consider changing:
change the hdd to 1tb it performs like the 10k raptors and add in a ssd when you can. clone hdd1 to ssd and push the 1tb into slot 2 for data storage after you wipe it out.
this would greatly increase the performance of your system. especially if you would like to be branching out from wow.
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 May 2010 at 4:16pm
the 1TB would be better I guess but he can always upgrade that, I didn't add it in cause it was over the budget, but if you can the 1TB is good advice from Raif.
