GTX 570 gpu temps too hot ?
Post Date: 2011-04-29
slicejones View Drop Down
  Quote slicejones Quote  Post ReplyReply bullet Topic: GTX 570 gpu temps too hot ?
    Posted: 29 Apr 2011 at 7:09pm
Hi,
I just got my new pc and i started playing Rift. I have the game video settings at 2560 x 1600 and everything set to Ultra.
I have 2 evga superclocked GTX 570's in SLI.
My video card temps are hitting around 75-80C when there's alot going on.
Is this too hot ?
The fans are set at 40% with a gradient increase as the temps go up. Should i change my fan settings ?
Thanks for any help.  Smile
Edited by slicejones - 29 Apr 2011 at 7:10pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Apr 2011 at 7:24pm
your fan should be at 80 - 100% when temps are around 80c.
your temps get into the hot zone and not good pass 85c.
570's max support temp is 97c.
your temps are fine for being under full load.
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 29 Apr 2011 at 9:51pm
those temps are fine, i wouldn't worry
dst- with the stock fan profile 80c is no where near 80-100% on the fans. Its more like 60%
Edited by RiceEatin2000GT - 29 Apr 2011 at 9:52pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Apr 2011 at 1:34am
I meant that he should have it set himself like that, so that the load temps are lower then 80c.
I should have been more clear.
  Quote slicejones Quote  Post ReplyReply bullet Posted: 30 Apr 2011 at 2:34pm
I'll create a new fan profile and give it a try.
Thanks alot for the help.  Smile
  Quote slicejones Quote  Post ReplyReply bullet Posted: 30 Apr 2011 at 4:10pm
New fan profile in MSI Afterburner works great. These are the new settings i went with and now my temps are around 55-65C instead of 75-80C at full load.
Temp/Fan Speed
30C/40%
40C/50%
50C/60%
60C/70%
70C/90%
80C/100%
Anything wrong with the fan settings i have ?
Thanks again !!
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 30 Apr 2011 at 5:31pm
Did you set it as a curve or step? Double clicking the graph changes it. Step will shoot up fan speeds to the next preset when that temp range is achieved, curve will gradually move it up. i.e., 55% on step will still set fan at 60%, while on curve it'll be at 55% according to your fan profile.
Also, you might want to play around with Temp Hysteresis a bit if it's switching around too much. Lets a bit of wiggle room between switches I believe.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote slicejones Quote  Post ReplyReply bullet Posted: 30 Apr 2011 at 5:39pm
I have it set on a curve.  It seems to gradually go up and down as i don't notice any major jumps up or down.
Liq View Drop Down
  Quote Liq Quote  Post ReplyReply bullet Posted: 15 May 2011 at 11:03pm
 Don't sweat it...I was playing Rift earlier and when things got busy I hit 78 degrees on a single GTX480. The Fermi cards are made to run warm, and especially since you're in SLI it isn't that bad. I remember hitting 90ish before I adjusted my fan profile, and added a 120mm to my HAF-X gpu shroud.
