GUIDE: Air-cooling for CPUs, GPUs
Post Date: 2007-08-05
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Topic: GUIDE: Air-cooling for CPUs, GPUs
    Posted: 05 Aug 2007 at 12:35pm
Taken from _Korruption_  at: http://hardforum.com/showthread.php?t=929824
These days, a lot of people are posting up topics looking for a good thermal solution for their new high-performance CPU. These people all have different needs, some are looking for something dirt-cheap, some look for low-noise, some look for good overall performance at a good price, some look for ease of installation, and others look for maximum performance with no boundaries (just keep it within air cooling ). Everybody's got different needs.
I usually cater to lower-noise setups, so you may substitute the Vantec Tornado in if you'd like. I'd like to keep my ears.
Air cooling doesn't have to be as complicated as it appears. It's a hell of a lot simpler than water cooling, and is usually a lot cheaper. The sheer selection you can find online is what usually scares people away. I decided to put together a quickie air-cooling guide, hopefully it'll be turned into a sticky where people can refer to it and perhaps add to it if I've missed anything. Constructive criticism, folks!
I'll lay it out in terms of Socket type (Socket A, Socket 478, Socket 754/939/940, LGA775). Lowest price in the respected socket type comes first. I'll re-use some of the descriptions because they may be the same across the different socket types. Saves me quite a bit of time too. Honourable mentions go in their respected sections.
Starting with the CPU cooling
Socket A (Athlon, Duron, AthlonXP, Sempr0n)
MASSCOOL 5F394B1L3G 80mm Copper HSF -- cheap at less than $14! The 80mm fan allows more airflow and less noise (the AMD retail thermal solution for Socket A comes with a small 60x60x10 fan which can be quite noisy), the all-copper heatsink body offers a good amount of surface area. Kinda reminds me of a cheaper (and perhaps noisier) Thermaltake Silent Boost. Even the three-pin lead is sleeved and shrinked! You really can't find another all-copper solution for this price.
Thermalright SI-97A Heatsink -- Please do note, this heatsink does not come with a fan! Moving slightly upmarket here at $34.95, but relative to what you can get out there, this is still very affordable. This is the new A revision, which adds compatibility to the new Athlon64 CPUs. Yes, you read that right, you can use this Socket A heatsink on your Athlon64 CPU when you upgrade down the road. Very cost effective. One of the best choices you can make for Socket A. It utilizes heatpipes to move heat from the heatsink base into the heatsink body above. You can have a very silent solution, or a very high-performance one, depending on the fan you choose. I'd recommend a low to medium speed 92mm Panaflo for all applications, even overclocking.
Honourable Mentions:
Zalman CNPS7000B-AlCu LED
Zalman CNPS7000B-Cu LED (non-LED models also available)
Socket 478 (Pentium 4)
ARCTIC COOLING Super Silencer4 Ultra 90mm HSF -- Dirt cheap P4 cooling for under $13. The Prescotts are known to run hot, so Arctic Cooling ups the fan size to 90mm for more airflow. The Intel retail thermal solutions really aren't that bad, they're just noisy. This one should definitely be significantly quieter than the box solution. Again, you get the patented
AC fan design, and the three-pin lead is sleeved and shrinked for cosmetics. Do remember that this thermal solution is designed for minimal noise, not maximum performance...
ARCTIC COOLING Freezer 4 ACFZ4 HSF -- More expensive at $29, but offers a lot more performance and still maintains the low-noise output. SilentPCReview gives it a favourable review. It uses heatpipes to transfer heat from the heatsink base to the heatsink body, and the fan blows air across the aluminum fins. If possible, mount the Freezer 4 so that the fan points towards the back of the case, the rear exhaust fan will help out and further reduce temperatures. Low-weight, low-price, low-noise, and high-performance.
Thermalright XP-90 -- Fantastic performance for $25 (again, this is a heatsink alone, no fan included). Paired up with a low to medium speed Panaflo, you can enjoy low-noise performance. The XP-90 is widely regarded as one of the best values in the enthusiast community, and SilentPCReview agrees. Easy installation too. If you don't want to deal with buying a separate fan, the XP-90 Retail Package is for you. A few bucks more and you get a decent mid-speed 92mm fan included.
Thermalright XP-90C -- The more-expensive ($48), all-copper brother to the XP-90. While the XP-90 features a copper base and aluminum heatsink fins, the XP-90C is an all-copper affair. One of the better performers on the market today, it offers much better compability than it's bigger brother (the XP-120, which will be covered later). Paired up with low to medium speed 92mm Panaflo, you'll be golden. Please be advised that the XP-90C is a very heavy heatsink -- exercise care when moving your computer! Many will argue that the SI-120 is a better choice, and I agree with them -- the SI-120 will allow for more airflow with less noise and less weight, and compatibility is pretty much guaranteed!
Thermalright SI-120 -- The updated brother of the XP-120. Costs about the same too. When that heatsink was introduced, the notion of using 120mm fans was a great idea. The main issue that gave many people problems was that it's size would interfere with other components on the motherboard. Thermalright, responding to customer concerns, went back to the drawing board and came up with the SI-120. Think of it as a larger version of the SI-97A. The heatsink body itself is raised high enough so that it clears just about everything on the motherboard. If you think you are going to have problems with the XP-120's clearance, do consider the SI-120. Pair this heatsink up with the Nexus Real Silent 120mm fan or the Yate Loon D12SL-12 (the same fan, but cheaper), you can have an almost inaudible thermal solution.
Thermalright XP-120 -- This is about as big as it gets! Priced around the same as the XP-90C ($48), you have to make a decision. If your motherboard fits this behemoth, you can get away with a very low-noise solution, or a maximum performance solution. Pair this heatsink up with the Nexus Real Silent 120mm fan or the Yate Loon D12SL-12 (the same fan, but cheaper), you can have an almost inaudible thermal solution. SilentPCReview gives it a good review. Or you can pair it up with a Delta high-speed 120mm fan. Your call. Just make sure it fits! You can check P4 motherboard compatibility here.
Scythe Ninja -- A giant heatsink originally meant for passive operation, but can accomodate a 120mm fan, which makes it a very potent choice for low-noise, low-temperature cooling. It features a whopping 12 heatpipes moving heat from the copper base up to the thin aluminum fins. Pair this up with a low-speed 120mm fan (Jab-Tech gives you the option of a 120mm Yate Loon, a fantastic choice), and you'll have fantastic cooling, perhaps even better than the Thermalright offerings. This heatsink seems to work well in the P180 case, with some people using the top vent as an intake and the rear vent as an exhaust. Only downside is that the whole assembly is pretty big.
Thermaltake CL-P0114 BIG TYPHOON 4 IN 1 Heatpipe CPU Cooler -- Well what do you know? I'm recommending a TT product! The main reason for that is because TT got the performance right this time, this thing really does offer a lot of cooling potential. Downsides are the blatant 16dBA marketing (though it is still decently quiet), the size (it is very tall), and the weight.
Zalman CNPS9500-LED -- Zalman's newest entry into the high-performance cooling market. At around $70, it definitely is pricey, even compared to the Thermalrights. What I like about the 9500 is the fact that you can point the CPU cooler exhaust at a rear case fan, so any heat produced will be taken out of the case quickly. Even with an all-copper design with more surface area than the previous Zalman flower heatsinks, weight is kept to a relative minimum. A FanMate2 is included so you can run the fan as slowly as you want. If you want the full 12V, disconnect the FanMate2 and plug the 9500 directly into the motherboard. As mentioned earlier, the orientation of the 9500 does matter, so do check out the fantastic instructions that Zalman has up.
Coolermaster Hyper48
Fans (80mm, 92mm, 120mm)
80mm Panaflo L1A (low-speed) -- one of the quietest 80mm fans you can buy (without sacrificing airflow). They are good for case fan duty or on a CPU heatsink if you're looking for overall quiet. This particular one comes in a 3-pin configuration, and no RPM monitoring. They're great workhorses.
80mm Nexus Real Silent -- Favoured in the silent computing community, these fans respond very well to undervolting (running the fan at less than the default 12V).
80mm Panaflo M1BX (medium-speed) -- Slightly faster (and slightly noisier) than the low-speed model, a better choice for CPU cooling where only 80mm fans will fit. This model supports RPM monitoring.
80mm Panaflo H1A (high-speed) -- Even more airflow but more noise than the medium speed. No RPM monitoring. This is where it starts getting noisy for my personal tastes.
80mm Enermax thermally-controlled fan -- If you need something that can be controlled by ambient temperature, consider something like this. 1700rpm at minimum speed is pretty slow, and should be quiet. Even at 2700rpm, it shouldn't be putting out over 30dBA of noise. I wonder if there's a way to override the temperature-control...
92mm Panaflo L1BX low-speed -- Very good fan overall for any CPU heatsink that can accomodate a 92mm fan. Supports RPM monitoring.
92mm Nexus Real Silent -- One of the quietest 92mm fans you can find, again, they respond well to undervolting. Supports RPM monitoring.
92mm Panaflo M1A medium-speed -- More airflow with slightly more noise. No RPM monitoring support.
92mm Panaflo H1BX high-speed -- Lots of airflow at a tolerable 35dBA. Supports RPM monitoring.
92mm Enermax adjustable fan -- The bigger brother of the 80mm adjustable model. Supports RPM monitoring.
120mm Yate Loon D12SL-12 -- Perfect for case fan duty or low-noise CPU cooling on an XP-120. The cheaper (but identical) version of the 120mm Nexus Real Silent. Famous in the silent computing industry, this fan responds well to undervolting. Supports RPM monitoring. (thanks Tiny)
120mm Coolermaster blue LED fan -- Offers a nice touch while still maintaining low noise levels. Lots of colours available! Supports RPM monitoring, as far as I know.
120mm x 38mm Panaflo L1A low-speed -- Please note, this fan is 38mm thick! Good airflow and low-noise where it fits. I'm pretty sure you can use this on the XP-120 to good effect. No RPM monitoring.
120mm x 38mm Panaflo M1A medium-speed -- Please note, this fan is 38mm thick! More airflow at a tolerable 35dBA. No RPM monitoring.
120mm Enermax adjustable fan -- The biggest version of the Enermax user-adjustable models, supports RPM monitoring.
Check out dtess17's thread on 120mm fans for some more insight!
A very valuable resource when shopping for fan is Sidewinder Computer's Listening Room. They don't have any Panaflo fans listed, but if you look for a fan with similar dimensions and RPM, you can get a rough idea as to how it will sound in reality.
VGA Cooling
Zalman VF700-ALCU Aluminum-Copper VGA Cooler -- This thing is capable of cooling the hottest video cards out there (on 12V, at least). For $26, you really cannot beat the power offered by the VF700. It isn't for true silent-PC enthusiasts, but for those looking to reduce noise and temperatures offered by the stock VGA thermal solution, the VF700 is something you should seriously consider. Often has problems clearing the nF4 chipset if you've got a larger passive thermal solution installed. Check the compatibility list!
Zalman VF700-CU Copper VGA Cooler -- The all-copper brother of the VF700Al-Cu. Offers more performance (as copper is able to remove more heat from the GPU), but also comes with more weight. The AlCu is for those who want to keep the weight hanging off their GPU to a minimum (the retention mechanism is very secure). I personally like the copper version better... as it looks better and I won't be moving my machine around. $4 more than the aluminum-copper hybrid. Often has problems clearing the nF4 chipset if you've got a larger passive thermal solution installed. Check the compatibility list!
Zalman VF900Cu -- The successor to the VF700, it incorporates two heatpipes to better distribute heat from the heatsink base into the copper fins. While it looks like it has more surface area than the VF700, it's weight is actually reduced. Again, it comes with a Fanmate2 for you to select fan speeds based on your tastes, and continues the tradition of being able to cool high-powered graphics cards (like the power hungry X1900XTX for example) quietly.
Zalman ZM80D-HP Aluminum, Copper Dual Heatpipe Noiseless VGA Cooler -- For those who have lower-powered VGA cards and wish for silent operation. A lower-powered card means nothing from the super-high-end range today, like the 7800 series or the X800 series cards. Those cards run quite hot and would function better with the VF700 series thermal solutions. Be warned, the installation process is fairly complex. Be sure to check if your video card needs the optional Zalman ZM-OP1 80mm fan if you have a more powerful VGA card.
Thermalright V-1 Ultra Aluminum heatpipe VGA cooler -- Newer revision of the original V-1, which had one less heatpipe. It also adds compatibility to the new
nVidia 7800 series graphics cards. An alternative to the Zalmans, seems to alleviate the problem of nF4 chipset clearance. An advantage of the V-1 Ultra is that you can use just about any 80mm fan on the main heatsink body, given that you have enough clearance from items above the video card. Another advantage if you're looking for maximum performance (I'm not), is that apparently you can mount another 80mm fan on the bottom side of the heatsink, basically the side that sits on the GPU core. Be sure to check the compatibility list and the instructions on the Thermalright site.
Arctic Cooling Silencers -- What these guys have that the others don't is that they can take air that is in the case, use it to remove heat from the heatsink body, and expel it out the case. This can dramatically reduce case temperatures depending on your setup. The other products from Zalman and Thermalright just expel the heat into the case, and depend on the rear exhaust fan to get rid of the heat. What you need to do here is figure out what ATI or nVidia card you have, go to this Arctic Cooling page and find which product you need (using the application section which outlines which solution is for which card). Then you can go to the retailer link above and make your selection. Arctic Cooling has lots of different models, it can be confusing. I've got a VGA Silencer Rev3 (the older model for the 9700). Great performing cooler, inaudible on low, and keeps the temperature down with it's vast surface area. Only gripe is that installation was a little tricky with my 9700's shim problem. I've done some installations with the NV Silencer 1, and that was very easy.
Chipset Cooling
ZALMAN ZM-NB32J NORTHBRIDGE HEATSINK -- Basic heatsink for $4. If you've got an nForce2 chipset, for example, with a failing chipset fan, like on the Abit NF7 boards, then something like this will work well. It is completely passive, so it'll never fail, and the surface area offered should provide better performance than the actively cooled heatsinks that Abit likes to put on their boards. If you don't have mounting holes around your chipset, then you can use the included thermal epoxy to mount the heatsink to whatever you want. Be warned, thermal epoxy is very permanent. I mounted this heatsink to my 8500LE for passive operation with good success (read more).
ZALMAN ZM-NB47J NORTHBRIDGE HEATSINK -- More surface area than the NB32J for a few cents more. People have mounted this heatsink to their hot-running nForce4 chipsets with good success, but you must make sure you have airflow moving around the heatsink, as it gets very hot. You'll need the mounting holes for this heatsink, as it doesn't come with epoxy. I've got one of these on my nForce2 chipset. Since it is a taller heatsink, it may get in the way of some nForce4 setups. You may need to do some bending of the soft aluminum fins to get everything to fit.
VANTEC CCB-A1C ICEBERQ SOLID COPPER VGA AND CHIPSET COOLER COMBO -- If you want active cooling, or are limited to the size of the heatsink you can install (with the nF4 boards, for example), try the Iceberq. It comes in a small footprint, so it should be able to clear most video cards, even in SLI mode, and will keep the chipset cooler than with the Zalman passive heatsinks. The all-copper design allows for a good amount of heat to be absorbed, and the fan is said to be decently quiet. You even get some extra aluminum heatsinks to mount on other components on your motherboard. There is an aluminum version of this heatsink floating around the market, but that comes with a sleeve bearing fan -- not good for hot chipsets.
Evercool EC-VC-RE Chipset Cooler -- The new specification from DFI, meaning these coolers are pretty much guaranteed to work on the DFI nF4 and RDX200 boards. It not only reduces noise, but brings temperatures down compared to the aluminum cooler that originally came on the LanParty boards. Cheap too!
SWIFTECH MCX159-CU EXTREME DUTY ALL-COPPER HEATSINK W/ 40MM FAN -- This heatsink-fan combo is about the best you can get for the money, but is a very tall solution and may not fit all motherboards and CPU heatsinks. The all-copper design removes a lot of heat, but may require a faster fan to dissipate all that heat. Luckily, Swiftech includes a Sunon VAPO bearing fan, which are said to be quieter and last longer than regular ball-bearing units.
Edited by skyR - 22 Oct 2007 at 7:02pm
Larry View Drop Down
  Quote Larry Quote  Post ReplyReply bullet Posted: 05 Aug 2007 at 3:41pm
Kelly you must truely love your job.   You have posted some great info on computers and how the internals all work together today.  The bad part is I am doing more reading on the forums than the work I need too.
  Quote Kelly Quote  Post ReplyReply bullet Posted: 05 Aug 2007 at 3:45pm
man, I don't even work on the weekends and I am sitting here doing this!  Yes, I definitely love my job.  I love customizing and pushing computers to their limits even more!
R-dawg View Drop Down
  Quote R-dawg Quote  Post ReplyReply bullet Posted: 09 Aug 2007 at 12:22am
All of this information you have provided lately has been great.  A lot of really interesting reads. Keep em coming.
In case of doubt, make it sound convincing.
  Quote Kelly Quote  Post ReplyReply bullet Posted: 09 Aug 2007 at 12:31am
thanks!  I will do my best!
Clinx View Drop Down
  Quote Clinx Quote  Post ReplyReply bullet Posted: 02 Sep 2007 at 7:59pm
Jeez, i only read half of it and i'm tired lol.
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 03 Sep 2007 at 4:46pm
According to the specs one has, will you recommend the cooling system that one should have?
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 03 Sep 2007 at 9:53pm
I just now re-read this post.  What the hell was I asking?  Man, I actually can't remember what I was asking here!
I think I'll step away from the laptop now and go to bed... pathetic.
Celedhring View Drop Down
  Quote Celedhring Quote  Post ReplyReply bullet Posted: 19 Sep 2007 at 12:25am
Arctic Cooling is what I use for my video cards. I highly recommend it although my present video card (7800GS AGP) runs so low in temperature that I haven't seen the need to add an aftermarket cooler to it.
Amazingly enough with stock cooling, it runs at 39C as I type this. When I run games such as WOW, it doesn't go higher than 43-44C maximum.
Celedhring
Minion View Drop Down
  Quote Minion Quote  Post ReplyReply bullet Posted: 19 Sep 2007 at 12:38am
Excellent posting Kelly.
Mortok View Drop Down
  Quote Mortok Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 2:05pm
ARRRG!  4 Forums later  & more information than my onboard RAM (brain) can handle.  Gotta go back to work so i can get some rest.  Great source of info for anything computer that i've seen before.
This page was generated in 0.1030273 seconds.
