H20: Stage 3: Digital Storm Exotic Custom Cooling
Post Date: 2013-05-20
Crono View Drop Down
  Quote Crono Quote  Post ReplyReply bullet Topic: H20: Stage 3: Digital Storm Exotic Custom Cooling
    Posted: 20 May 2013 at 10:32am
I've ordered my Syndicate with the H20: Stage 3: Digital Storm Exotic Custom Cooling System (CPU Only). What kind of maintenance should I expect to do? Is it something that I could do easily?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 20 May 2013 at 12:03pm
Just top off the reservoir when needed. Probably every few months.   Easy to do and the fluid is FluidXP.     You can have DS send some with the order or just get from various websites like www.Frozencpu.com    .
You might have to drain and replace every couple of years.
Good luck and enjoy.
  Quote Alex Quote  Post ReplyReply bullet Posted: 20 May 2013 at 2:12pm
Well said. It's not too hard to maintain, we can always walk you through it when the time comes.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 22 May 2013 at 12:34pm
 Strong
  Quote oldlady RPGer Quote  Post ReplyReply bullet Posted: 27 May 2013 at 7:07am
I recently changed the liquid in my cooling system. With the Syndicate it was really easy to get to everything. But I had never done this before so that took a while.
  Quote retirednavysnipe Quote  Post ReplyReply bullet Posted: 28 May 2013 at 7:40am
I have had my Hailstorm for over a year now and I have yet to touch my cooling system. Fluid levels have not changed in probably 11 months since they changed a little when system was new. But I do have fluid on hand if need be.
Just check that level every day and fill when needed.
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
