HAF 922 case fans
Post Date: 2009-09-11
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Topic: HAF 922 case fans
    Posted: 11 Sep 2009 at 4:10pm
Hi all,
I'm planning oin installing another GTX 275 in  my rig.  I want to keep everything cool.  With my HAF 922 what is the best arangement of fans with my current fans, which are:
2x200mm @ 110cfm
4x120mm @ 90cfm
I was thinking of:
top 200mm going out
back 120mm going out
front 200mm going in
side 120mm out & 120mm in
bottom 120mm in
this would keep all pressure equal inside case i think.  is their a hard rule to this or something I have to play with?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 5:41pm
people have played around in the past with other cases and the airflow did not make much of a difference.
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 5:44pm
OK.  So one could say that it isn't a major science and to just get air moving through the case and I'll be cool?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 5:46pm
I think the setup the 922 came in is the best, if you chance it at best you may get/lose 2c.
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 5:55pm
OK thanks.  I may just replace the non led fans with same size led ones just for the fancy effect. lol
Thanks for your advice.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 6:08pm
My pleasure, good luck
