haf 932 fan help
Post Date: 2010-04-19
rogueunicorn View Drop Down
  Quote rogueunicorn Quote  Post ReplyReply bullet Topic: haf 932 fan help
    Posted: 19 Apr 2010 at 9:23pm
on the haf 932, i've been wanting to replace the back 140mm and the front led 230mm fan with xigmatek fans. the only problem is, on the front 230mm fan the cfm is listed at 110, but the xigmatek fan i want to replace it with is only 61 cfm. will this hurt my overall temps/overclock?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 1:58am
I would not change the stock fans with xigmatek, that is bad idea, that kills the whole ariflow the haf is so famous for, it has the great airflow cause it has 3 x 230mm fans, change those fans with a 120mm or 140mm and you airflow sucks.
