HAF 932 front fan
Post Date: 2009-11-21
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Topic: HAF 932 front fan
    Posted: 21 Nov 2009 at 12:04pm
I've been thinking alot lately if I want to go through the trouble of manually replacing the fan on the 932 and putting in the smaller fan that was supposed to be put in so I wouldn't have to think this much about it Big%20smile
A thought occurred to me though, is there any spot on the current front fan that I can disconnect, break off or sauder off or whatever that would disable the LCD light but leave the fan running. I realize my problem isn't the fan, it's the fact it's red. I can get another lcd light if needed and those are easier to put in than replacing this fan with a smaller one that I have no mount for.
Any suggestions?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Nov 2009 at 5:05pm
what color? you can get the 230mm blue one from cm, so you don't have to replace it with a smaller one, or you can just replace it with the one that is on the side panel which is a 230mm fan with no led.
Edited by DST4ME - 21 Nov 2009 at 5:06pm
titusmckieus View Drop Down
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 3:24am
The front fan is quite easy to replace. and as DST4ME has pointed out. you can just get a replacement fan from Coolermaster.
This is why I wish we had a for sale or trade section on here. although I do know that it would take a bit of resources to moderate it
It could prove be useful in times like these. I'm sure we all have spare stuff sitting around from past upgrades that we would like to sell or trade. instead of collecting dust.
I heard it mentioned on here before but never heard anything else about it.
Edited by titusmckieus - 22 Nov 2009 at 3:31am
  Quote satsunada Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 5:31am
Ok, found the blue replacement fan on CM's website for 20 bucks. I guess I'll buy it next paycheck and go from there. Lil iffy right now. Hopefully I won't break much :P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 9:28am
you have the manual on how to replace it?
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 12:01pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 5:15pm
ok good
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 9:22pm
If you wanted you could put in two 120mm (pretty sure).  I think that would open up the color green to you as well.
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 9:25pm
Their is a button that turns off the front led.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 11:00pm
rated at 19 dBA for the 230mm front fan why would you want 2 smaller fans that are nosier . the fan that has a LED on/ off switch is the 200mm fan found in the 922 Haf.  I believe. the 230 mm fan does not have that option.
If you want a different color you could always do this
http://www.overclock.net/air-cooling/584879-230mm-fan-led-upgrade-cooler-master.html
Edited by titusmckieus - 22 Nov 2009 at 11:01pm
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 11:09pm
I was thinking of the 922 you are correct.
With 2 smaller fans it would make the more noise but would be subjective if you cared or not.
Sorry about mistake.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 11:43pm
No prob.
 If the other person is interested. I would be willing to do a trade for my extra non LED for his Red LED. strait across trade
Opps, just seen he wanted the blue Never mind
Edited by titusmckieus - 22 Nov 2009 at 11:44pm
This page was generated in 7.128906E-02 seconds.
