HAF 932 noise
Post Date: 2009-09-25
Ewsaind View Drop Down
  Quote Ewsaind Quote  Post ReplyReply bullet Topic: HAF 932 noise
    Posted: 25 Sep 2009 at 3:01pm
Hello, I just received my gaming desktop.
Config ID: Configuration Name:
Q:
DSO-157125 Digital Storm Desktop 157125 1
Trim Accents: - No Thanks
Processor: Intel Core i7 920 2.66GHz (Quad Core) Factory Overclocked to 3.75GHz
Motherboard: EVGA X58 SLI LE (Chipset: Intel X58)
System Memory: 6GB DDR3 1600MHz Corsair/Mushkin (Digital Storm Certified) (Hand Tested)
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card(s): 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Sound Card: 7.1 24-bit / 192kHz Decoding High Definition Integrated Audio
Extreme Cooling: H20: Stage 1: Asetek Liquid CPU Cooler
Liquid Color: - Not Applicable, I do not have a H20: Stage 3 Cooling System Selected
CPU Boost: Yes, Factory Overclocked i7 920 from 2.66GHz to 3.75GHz with 100% Stability & Reliability
Memory Boost: - No Thanks
Windows Boost: Yes, Disable and tweak all of the non-crucial services on the operating system
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Priority Build: Ship Within 72-Hours After Order Is Successfully Processed
My problem is this. It is so loud!! I know it is supposed to be loud for the cooling it is doing, but my desire is to have it not idling this loud when browsing a forum, haha.
Is there anything I can do that will not void a warranty or something? I am fine with some noise and I would be more than be glad to pay for new fans if I have to be satisfied.
I don't know how much more I can say... it really is simple. It is loud and I'm desperately seeking a solution for this beautiful machine :D
All else said and done, digital storm - you rock!
Techkai View Drop Down
  Quote Techkai Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 3:18pm
In the reviews most if not all of them said the haf 932 was relatively quiet. How loud would you say yours is (blow dryer, leaf blower or jet engine loud)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 3:20pm
open your case and see where the noise is coming from, those 1250w psu can be loud and one the reasons why I don't like the pre-builds so much, but its personal preference.
anyways open the case and see if the noise is coming from gpu or psu.
if its gpu then you just set the fans to auto on them, using the app precision, if its the psu, then there is nothing you can do.
Edited by DST4ME - 25 Sep 2009 at 3:21pm
Drakul View Drop Down
  Quote Drakul Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 3:24pm
My guess would be the GPU's  I got a HAF prebuild also and the case fans are relatively quiet, but since so much of the case is grill you can really hear my GPU fans when they crank up, which is pretty much all the time since I am crunching with it any time I'm not on it.
  Quote Ewsaind Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 3:32pm
and it was the GPU! Thanks guys. The precision application is really nice also.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Sep 2009 at 3:37pm
ok then good, now the fans on auto means that they will run on high only when the gpu is under load so, when its under load its gonna be loud but when its idle it will be quite.
