HAF Blue LED 230mm
Post Date: 2009-02-14
  Quote DST4ME Quote  Post ReplyReply bullet Topic: HAF Blue LED 230mm
    Posted: 14 Feb 2009 at 6:07am
If you have a HAF with blue lights you can change your side panel regular 230mm fan or the front 230mm Red led fan with a blue led one
HAF Blue LED 230mm
they had the red one but ran out I guess, I can't find it on their site, I'm sure if you call the number in that link you can order one or something.
Edited by DST4ME - 14 Feb 2009 at 6:11am
Mathew57 View Drop Down
  Quote Mathew57 Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 12:29am
Thanks DST4ME i ordered a few for my HAF case i hope they look ok with UV lighting and the UV Blue glowing fluidErmm.
Mathew57
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 12:59am
well if you got LC on yours then the only 2 you can change is the driver fan (front) and the side fan
they should be the same as red but blue
e06028 View Drop Down
  Quote e06028 Quote  Post ReplyReply bullet Posted: 24 Feb 2009 at 2:56pm
Well dang I did not know that if I ordered the HAF with blue lights that the fans would be red.  I thought that DS would make sure everything matched but guess not.  I will order these now so that when the PC gets here I can install the blue fans.
Thanks DST4ME, I would have been surprised to see blue lights with red fans.
  Quote e06028 Quote  Post ReplyReply bullet Posted: 24 Feb 2009 at 3:00pm
So I only need two of these right?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Feb 2009 at 5:26pm
the HAF comes with that one red fan, so DS has no choice over that, unless you get the fan upgrade, which is led but its a smaller fan.
if you have LC then ya you only have the front fan and the side fan
waiting for them to get the red one back in stock myself
Edited by DST4ME - 24 Feb 2009 at 5:26pm
