HAF-X Front Blue LED Fan
Post Date: 2010-08-01
SemperFuzz View Drop Down
  Quote SemperFuzz Quote  Post ReplyReply bullet Topic: HAF-X Front Blue LED Fan
    Posted: 01 Aug 2010 at 10:24am
For those looking to change the Red Led Fan up front this Yate Loon looks like just the ticket.  Can the forum masters weigh in if it will work?  Coolermaster does not currently offer the 230x30mm blue led fan right now
Thanks
In need of a cooling fan to keep temps in order? Try the Yate Loon 230 x 30mm Blue LED Fan, it can be used as an exhaust fan or intake fan.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 01 Aug 2010 at 10:31am
220x30mm fan, frame dimensions are off. Sure it'll mount correctly in the 230mm frame? 1cm is a minuscule gap, but a gap nevertheless.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 01 Aug 2010 at 7:44pm
well you can force it if you need to, thats not a big deal, but what are you trying to accomplish here? just color? thats a fine change, the ratings look better than the cooler master stock fans, but also louder, so keep that in mind
This page was generated in 1.855469E-02 seconds.
