HAF X Side Fan
Post Date: 2010-07-12
Z0GT View Drop Down
  Quote Z0GT Quote  Post ReplyReply bullet Topic: HAF X Side Fan
    Posted: 12 Jul 2010 at 12:03pm
Hope this is the correct place to be posting this, but I just received my new DS system and got it all up and running (will post a review later on), and I noticed that the side fan on the HAF X case wasn't hooked up. I haven't messed around with hardware in the longest time and I can't for the life of me find where I need to plug it in, I assume the power supply but it's rather difficult to get to and I'd rather not start moving things around before I was entirely sure. I also started up the PC without connecting that particular fan, am I running the risk of overheating, or will the one fan not make a huge difference?
Any help is appreciated.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 12 Jul 2010 at 2:29pm
ha you definitely want to plug it in, its unhooked becuase you have to take out the foam..
the cord is most likely in the bottom right side if you are looking in to the case with the side off, if you can take a picture and ill point you to some spots you should find the connection
Z0GT View Drop Down
  Quote Z0GT Quote  Post ReplyReply bullet Posted: 12 Jul 2010 at 3:36pm
Well now I feel kind of foolish, I popped the case back open and sure enough the connector was right there, it was just tucked up under the bottom lip of the case. Thanks much for your help, I probably would have never found that if I didn't know where to look.
