HAF32 case fans?
Post Date: 2009-04-28
CloveMan3 View Drop Down
  Quote CloveMan3 Quote  Post ReplyReply bullet Topic: HAF32 case fans?
    Posted: 28 Apr 2009 at 9:10am
Are the fans that come with the case substantial enough to get the job done or should I spring for the Chassis Airflow upgrade option (Upgrade Chassis With Zalman Performance Fans (Up to 6 Fans))?
Also would the Zalman fans be the same size as the HAF32 fans or would they  be smaller and just more of them?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Apr 2009 at 5:01pm
the HAF comes with 3 x 230mm fan, zalmans are 120mm fans
airflow upgrade depends on what you are getting, most time the HAF stock is good.
