Hailstorm Liquid Cooling Issue.
Post Date: 2011-08-28
Mortraven View Drop Down
  Quote Mortraven Quote  Post ReplyReply bullet Topic: Hailstorm Liquid Cooling Issue.
    Posted: 28 Aug 2011 at 8:38pm
To the DSO community and staff:
I'm new to posting on the forums but I've been reading them for about 6 months now. I recently ordered the Hailstorm case with Tri 580's With CPU+Chipset+GPU LC.
My question is, will it come with an external radiator on the back? I've noticed that some builds posted on the forums have an external radiator and that is not something I want.
Are they extra? or will mine come like that? If the answer is yes I'll need to put a hold on my system until I figure out what to do.
Thanks for your time.
-Mortraven
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Aug 2011 at 1:38am
You see the rad in the bad cause we want/need a bigger rad to get better temps, for example I have a tri rad for the cpu/mobo on top inside and then you see the triple rad in the back for the four 480 gtx, but that is custom lc system with much better performance.
you gonna endup with a single rad for cpu and dual rad for gpu and all should be inside.
  Quote Mortraven Quote  Post ReplyReply bullet Posted: 29 Aug 2011 at 2:56am
Thank you DST4ME, you put my mind at ease. :)
-Mortraven
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Aug 2011 at 4:41pm
My pleasure and good luck
